AOA probe design
willie.harrison(at)tinyon
PostPosted: Thu May 08, 2008 11:46 pm    Post subject: AOA probe design Reply with quote
Folks,
I am looking for a sensible AOA probe to feed my Dynon D100. The
Dynon probe is ghastly - very big and heavy so I won't use that.
I can't see what's wrong with a small, light weight probe based on
the same principle, ie an angled face with a hole in it. Has anyone
else designed their own and if so how well did it work?
Anyone know of a good off the shelf probe suitable for the Dynon?
Many thanks
Willie Harrison
G-BZNY - a plane about to be reborn after an 700 hour rebuild....
rowil(at)clara.net
PostPosted: Fri May 09, 2008 3:39 am    Post subject: AOA probe design Reply with quote
I don't know of an off-the shelf probe, but I wonder if something
like the attached PDF would do the trick. Any half-competent machine
shop should be able to produce a similar item, even scaled down a bit
if thought desirable.
I found the file in my "AOA" folder and I'm afraid I don't know where
I got it, although the "airsoob" part of the filename is probably a
clue.
regards
Rowland
| Wilma & Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
airsoob_aoa_probe.pdf
 Filename:  airsoob_aoa_probe.pdf
 Filesize:  103.39 KB
 Downloaded:  391 Time(s)
PostPosted: Fri May 09, 2008 5:56 am    Post subject: AOA probe design Reply with quote
Many thanks, Roland, that's very helpful.
Best wishes
Willie
> anyone else designed their own and if so how well did it work?
machine shop should be able to produce a similar item, even scaled
down a bit if thought desirable.
where I got it, although the "airsoob" part of the filename is
probably a clue.
regards
Rowland
'w' ...<airsoob_aoa_probe.pdf>
rparigor(at)suffolk.lib.n
PostPosted: Fri May 09, 2008 12:37 pm    Post subject: AOA probe design Reply with quote
Have a look at my Homegrown AOA at:
http://www.europaowners.org/modules.php?set_albumName=Begin-06-2003&op=modload&name=gallery&file=index&include=view_album.php
under:
Homegrown AOA.
Ron Parigoris
