willie.harrison(at)tinyon Guest
Posted: Thu May 08, 2008 11:46 pm Post subject: AOA probe design |
Folks,
I am looking for a sensible AOA probe to feed my Dynon D100. The
Dynon probe is ghastly - very big and heavy so I won't use that.
I can't see what's wrong with a small, light weight probe based on
the same principle, ie an angled face with a hole in it. Has anyone
else designed their own and if so how well did it work?
Anyone know of a good off the shelf probe suitable for the Dynon?
Many thanks
Willie Harrison
G-BZNY - a plane about to be reborn after an 700 hour rebuild....
rowil(at)clara.net Guest
Posted: Fri May 09, 2008 3:39 am Post subject: AOA probe design |
At 2008-05-09 08:42 +0100 William Harrison wrote:
| Quote: | I am looking for a sensible AOA probe to feed my Dynon D100. The
I don't know of an off-the shelf probe, but I wonder if something
like the attached PDF would do the trick. Any half-competent machine
shop should be able to produce a similar item, even scaled down a bit
if thought desirable.
I found the file in my "AOA" folder and I'm afraid I don't know where
I got it, although the "airsoob" part of the filename is probably a
clue.
regards
Rowland
| Wilma & Rowland Carson http://home.clara.net/rowil/
| <rowil(at)clara.net> ... that's Rowland with a 'w' ...
airsoob_aoa_probe.pdf |
103.39 KB |
394 Time(s) |
Posted: Fri May 09, 2008 5:56 am Post subject: AOA probe design |
Many thanks, Roland, that's very helpful.
Best wishes
Willie
> anyone else designed their own and if so how well did it work?
machine shop should be able to produce a similar item, even scaled
down a bit if thought desirable.
where I got it, although the "airsoob" part of the filename is
probably a clue.
regards
Rowland
'w' ...<airsoob_aoa_probe.pdf>
rparigor(at)suffolk.lib.n Guest
