Trim tab play
Goto page Previous  1, 2
moorecomp
PostPosted: Tue May 13, 2008 7:01 am    Post subject: Re: Trim tab play Reply with quote
Andy,
Check out how Larry Martin put spring loaded nosewheel steering on his 701. Larry is a master tinkerer.
http://www.skyhawg.com/petals.html
(yes, pedals is mispelled)
Best regards,
Craig Moore A&P
Mancelona, MI
Gig Giacona
PostPosted: Tue May 13, 2008 8:16 am    Post subject: Re: Trim tab play Reply with quote
Three reason, complexity, complexity and complexity. Did I mention complexity?
I don't have my engine on the mount yet but I do have a big piece of concrete that is there to counter balance somewhat but it is not stretching the bungee at all. I can with some force move the gear stop to stop sitting in the hanger. I have not put any lube on it at all. I just can't see changing the design for what is really just a transient issue that will work itself out as the system wears in a little.
You are also planing to put a Corvair engine in as I am and the Corvair is on the up end of the weight scale for the 601. You don't need any extra weight out there in front.
[quote="ashontz"]What's wrong with it?
[quote="Gig Giacona"]Good God Why?
do not archive.
ashontz wrote:
Is anyone using a Cessna style spring loaded front wheel steering instead of a hard mount on the wheel? I kind of figured that's the way I'd like to go when the time comes.
W.R. "Gig" Giacona
601XL Under Construction
Terry Phillips
PostPosted: Tue May 13, 2008 10:09 am    Post subject: Trim tab play Reply with quote
Best regards,
Craig Moore A&P
Mancelona, MI
Craig
Thank you for this post. I've been concerned about the interaction between
the direct link nose wheel and the behavior in Montana's winds, and Larry's
solution looks to be a good way to go.
Terry
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
ggower_99(at)yahoo.com
PostPosted: Tue May 13, 2008 10:47 am    Post subject: Trim tab play Reply with quote
Probably because in Experimental Aviation, we all are test pilots Smile
Saludos
Gary Gower
701 912S Strictly to plans built and happy test pilot.
Do not archive.
Gig Giacona <wrgiacona(at)gmail.com> wrote:
[quote]--> Zenith601-List message posted by: "Gig Giacona"
Good God Why?
do not archive.
W.R. "Gig" Giacona
Read this topic online [quote][b]
Gig Giacona
PostPosted: Tue May 13, 2008 12:54 pm    Post subject: Re: Trim tab play Reply with quote
I fully understand the whole experimental aviation thing. BUT to do it before you know there is a problem is just silly UNLESS you are wanting to just test different ideas.
Andy, who I was responding to, has not said he wants to be a tester, he wants to have a safe aircraft. If a problem is there after he puts the gear on then fix it. If it is done before you even know there is a problem you won't know if a problem that the change causes is better or worse than the problem that might or might not be there.
W.R. "Gig" Giacona
Page 2 of 2
