RV-4 Firewall Modification / Governor Retrofit...
Site Admin
PostPosted: Sun May 04, 2008 2:51 pm    Post subject: RV-4 Firewall Modification / Governor Retrofit... Reply with quote
Hi Listers,
I'm working on the prop governor firewall retrofit on my RV-4 firewall
and its actually is coming out pretty nice. Here are a few pictures of
what's involved if you've not yet had this pleasure...
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout1.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout2.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout3.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout4.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout5.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout6.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout7.jpg
So here's my question: What type of rivets are used for the retrofit?
Considering that I will be using that yucky, gray gunk to seal
everything coupled with the fact that access to both sides of the
rivets will be restricted at best, I'm wondering if some pop rivets
might be in order? I note that the type of rivet isn't called out in
the little instruction sheet that came with the retro kit (a flat sheet
of stainless.) Anyway, what's the consensus on using pop rivets here?
If it seems okay, what type would be best?
As always, thanks to all for the help,
RV-4 #1763, N442RV to be...
JFLEISC(at)aol.com
PostPosted: Sun May 04, 2008 3:33 pm    Post subject: RV-4 Firewall Modification / Governor Retrofit... Reply with quote
In a message dated 5/4/2008 6:54:07 P.M. Eastern Daylight Time, dralle(at)matronics.com writes:
I did one of those retrofits and, assuming the engine is out, I had no problem with standard AN rivets even bucking them myself.
Jim
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
