AZFlyer
Posted: Sat May 03, 2008 2:47 pm Post subject: Cabin Access Steps |
Has anybody added a bolt or two to 6G3-2 (where the pipes come together under fuselage?) Makes sense to me, but not being an Aeronautical Engineer, I really hate to crash because of a couple added bolts.
Seems like it would strengthen the steps on both sides.
DO NOT ARCHIVE
Mike
I need to search archives also...
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
bryanmmartin
Posted: Sat May 03, 2008 3:10 pm Post subject: Cabin Access Steps |
I had it welded at a local shop.
added bolts.
DO NOT ARCHIVE
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat May 03, 2008 6:04 pm Post subject: Re: Cabin Access Steps |
I also had mine welded. First I drilled a couple of centering holes, pinned it and had it tig welded. It DOES add strength.
If you search the Zenith archive you will see that we previously had a good discussion on this issue.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Posted: Sat May 03, 2008 6:37 pm Post subject: Cabin Access Steps |
I think Larry Macfarland provided a link to a photo of how he did it the
last time this came up. He (or someone else) boxed it in with two "L"
extrusions fastened to the bottom of the fuselage.
-- Craig
AZFlyer
Posted: Sat May 03, 2008 6:59 pm Post subject: Re: Cabin Access Steps |
I have found and read the archive on this subject. Thanks to all those the replied. I think a couple bolts would stiffen things up a bit.
Thanks again,
Mike
DO NOT ARCHIVE
