RV-4 Firewall Modification / Governor Retrofit...
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
Site Admin
PostPosted: Sun May 04, 2008 2:50 pm    Post subject: RV-4 Firewall Modification / Governor Retrofit... Reply with quote
Hi Listers,
I'm working on the prop governor firewall retrofit on my RV-4 firewall
and its actually is coming out pretty nice. Here are a few pictures of
what's involved if you've not yet had this pleasure...
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout1.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout2.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout3.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout4.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout5.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout6.jpg
http://www.matronics.com/MattsRV4/MiscPictures/GovernorCutout7.jpg
So here's my question: What type of rivets are used for the retrofit?
Considering that I will be using that yucky, gray gunk to seal
everything coupled with the fact that access to both sides of the
rivets will be restricted at best, I'm wondering if some pop rivets
might be in order? I note that the type of rivet isn't called out in
the little instruction sheet that came with the retro kit (a flat sheet
of stainless.) Anyway, what's the consensus on using pop rivets here?
If it seems okay, what type would be best?
As always, thanks to all for the help,
RV-4 #1763, N442RV to be...
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
ceengland(at)bellsouth.ne
PostPosted: Sun May 04, 2008 6:33 pm    Post subject: RV-4 Firewall Modification / Governor Retrofit... Reply with quote
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
