Catz631(at)aol.com Guest
Posted: Wed Apr 30, 2008 4:05 am Post subject: Rotax 912 UL engine run on |
Yesterday at engine shutdown (after an uneventful flight) a weird thing happened. My 912UL kind of stopped then rotated 3 revolutions backwards. It sounded just like an old car with engine run on when you shut it down (ie; it had a knocking/pinging/ spitting sound)
The outside airtemp was about 70 degrees .The water and oil temps were normal.The indicated engine rpm was 1800- 2000 at shutdown. The only thing that I can think of that might have caused it was the fuel.It was car gas about two months old and 87 octane which I keep in a 30 gal bowser. The plane (Kitfox)had been down for two months for various mods on my aircraft.
I called several people to ask if they had ever seen this happen ( Thanks John !) I also called Lockwood and they recommend that I purge the oil system for possible induced air in the oil system. The tech had never heard of this happening. I will purge the system and check the valve clerances, then "burp" the system. I have also bought some fresh high test auto fuel to try to see if that helps.
Has anybody ever had this happen? And if so any possible damage ? I have seen this on occasion with small Continentals but the Rotax is not suppose to do this.
Thanks !
Dick Maddux
Kitfox4-1200
Rotax912UL
Pensacola,Fl
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Fri May 02, 2008 4:15 pm Post subject: Re: Rotax 912 UL engine run on |
Dick,
Also give Ronnie Smith a call at South Mississippi Light Aircraft (Lucedale, MS) and ask him about this event. Please tell him I told you to call!
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
