pwmac(at)sisna.com Guest
Posted: Wed Apr 30, 2008 6:02 am Post subject: Another fat wire lug connection |
Comments solicited
http://fordfuelinjection.com/?p=59
The world of car battery connections. The link shows a popular way to deal with soldering the big cables.
The last pic also shows his alt to batt cable with the fat fuse. Used for high amp alts for the off road guys.
Paul [quote][b]
echristley(at)nc.rr.com Guest
Posted: Wed Apr 30, 2008 8:44 am Post subject: Another fat wire lug connection |
paul wilson wrote:
| Quote: | Comments solicited
<http://fordfuelinjection.com/?p=59>http://fordfuelinjection.com/?p=59
Paul
Good-gawd!!!
The propane torch is WAY oversized for this job. It's like using a Mack
truck to race around a picnic table 8*)
Get one of the $8 butane torches. They're useful for all sorts of
things other than making fat cables, and you won't set the house on fire
doing it 8*)
Bob McC
Posted: Wed Apr 30, 2008 8:47 pm Post subject: Another fat wire lug connection |
Ernest;
While I agree with you totally, you must admit that the results depicted in the photos appear to be pretty good.
Bob McC
DO NOT ARCHIVE
[b]---
_________________ Bob McC
Falco #908
(just starting) |
Peter Laurence
Posted: Thu May 01, 2008 4:07 am Post subject: Another fat wire lug connection |
Where does one find the solder plugs/
P Laurence
Bret Smith
Joined: 09 Jan 2006 Posts: 178 Location: Mineral Bluff, GA
Posted: Thu May 01, 2008 5:39 am Post subject: Another fat wire lug connection |
In answer to your Q: I cannot find the pellets here in the CO boondocks and I never bothered to goggle them out. I use a small torch and just feed the solder until the cable seats in the lug.
An interesting point: The weld cable I am now able to get, unlike Ryan's, melts at a low temp. My method worked fine when I was able to get the dual insulated welders cable. That stuff would not melt even with the overkill torch. With the local obtained cable I have to get the nearby battery guy to crimp the lugs with his pro crimper. I would prefer the better cable, but the dual insulation makes it slightly stiffer.
I have bought Ryan's alt and cables for my off road trucks. No problem with his service if you need a 175 or 200 amp alt. These alts are '90s to the present Ford units with the regulator attached to the back of the alt. Here is his link. He does not appear to sell pellet separately. [url=http://rjminjectiontech.com/?p 2] http://rjminjectiontech.com/?p 2[/url]
Here is a repeat of the guys diy method. Remember he deals with a lot of guys with no clue on how to deal with electrical stuff.
Paul
At 06:02 AM 5/1/2008, you wrote:
[quote]Where does one find the solder plugs/
P Laurence
Posted: Thu May 01, 2008 9:08 am Post subject: Another fat wire lug connection |
Robert McCallum wrote:
| Quote: | Ernest;
Indeed, I must. But how many charred remnants are on the floor? (Or in
his trash can if he isn't as messy as me.)
We're mostly manufacturing one-offs. How many battery cables do you
expect to make in your life? You -could- do the job with a #6 welding
torch set to a large oxidizing flame given enough practice (not that
I've tried it, mind you). Those little butane torches are a godsend in
many applications. This being one of those.
nuckolls.bob(at)cox.net Guest
Posted: Thu May 01, 2008 4:21 pm Post subject: Another fat wire lug connection |
At 12:39 AM 5/1/2008 -0400, you wrote:
| Quote: | Ernest;
Bob McC
DO NOT ARCHIVE
> Good-gawd!!!
> doing it 8*)
I've done this job with all sizes of torches including the
standard hardware store variety depicted. Up until a few
months ago, my all time favorite for this size job was
the Bernz-O-Matic ST100T
http://www.aeroelectric.com/Pictures/Tools/Soldering/Gas_Tools/ST100T_Microtorch_small.jpg
I used to get them a Home Depot and Lowes for about
$10 each. They seem to have disappeared from the US
market but they seem to be available in the UK.
There's a variety of small gas tools depicted on
my website at:
Any one of these tools would be very convenient
sources of heat for putting the terminals on fat-wires.
Posted: Thu May 01, 2008 4:24 pm Post subject: Another fat wire lug connection |
At 08:02 AM 5/1/2008 -0400, you wrote:
| Quote: | Where does one find the solder plugs/
They're a specialty item that's totally
unnecessary to the task. For closed barrel terminals
like that shown in the article, pre-tin your
conductors out in the open. Heat the terminal
and fill the wire-grip about 1/3 full of solder.
Then bring the wire strands up to the rear
of the wire grip . . . warm them along with
the terminal until the solder softens and then
slowly immerse the wire into the terminal.
I prefer the open barrel terminals like those
shown in:
http://aeroelectric.com/articles/big_term.pdf
This style terminal lends itself to "copper-
wedging" so that you can minimize dependency
on solder to fill the joint. You can also
apply solder as needed from the proper end
and avoid overheating the wire's insulation.
( -Thomas Paine 1776- )
grjtucson
Posted: Thu May 01, 2008 7:22 pm Post subject: Re: Another fat wire lug connection |
I just got one of these:
http://www.aeroelectric.com/Pictures/Tools/Soldering/Gas_Tools/Pencil_Torch_2.jpg
at Ace Hardware for about $12. Kind like a refillable BIC lighter with an attitude.
Worked great to make ground buses, I suspect it'll do a bang-up job on my fat wire terminals.
George
_________________ George Jenson - http://www.georgejenson.com
Tucson, AZ - RV-7 Standard Build
Empennage Completed 1/06
Wings Completed 11/06
Fuselage in Progress |
