Upper Engine Mount (BRS Style)
MHerder
PostPosted: Sun Apr 27, 2008 8:21 pm    Post subject: Upper Engine Mount (BRS Style) Reply with quote
My drawings show the old style of upper engine mount without BRS, it looks like I need to drill the new one for the 3/8" bolt. Is this correct?
Do I just drill in the center of the box. I just made an x to center it but have not drilled yet?
I am now adjusting the fuselage level, plumb, square etc and it appears that you might be able to make a very small adjustment to the longeron level by drilling a little out of center but I would really feel much better about having this 3/8" hole as close to center as possible.
Does anyone have some photos that detail this a little better. I also need dimensions for the bolts that go to the longeron. I would have liked to have seen this area detailed a little better in the drawings.
Thanks in advance for your help!!!
Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying
PatrickW
PostPosted: Mon Apr 28, 2008 9:27 am    Post subject: Re: Upper Engine Mount (BRS Style) Reply with quote
Recommend pinging Zenith on this one, so they know more people are wondering about this, and to get the most-current information from them.
In the meantime, here is a diagram somebody sent me:
http://picasaweb.google.com/Patrick.Hoyt/Zenith601XLBRSBrackets/photo#5190655085433945250
Were any of the other BRS brackets included in your kit? I got just the triangular engine mount ones, but the diagram also shows ones towards the back, near the baggage area. May have to fabricate those, I'm guessing out of 4130. Or maybe a mountpoint across the main gear instead. Just an idea..
Patrick
XL/Corvair
cookwithgas
PostPosted: Fri May 02, 2008 5:33 am    Post subject: Re: Upper Engine Mount (BRS Style) Reply with quote
Patrick:
Wow! There are lots of ways to skin a cat! (my daughter's least favorite expression). My BRS mounts are completely different from either of the drawings you posted. I got my drawings from BRS, then sent them back some small revisions for the XL since their drawings were for the non-XL 601.
I have an extra attach point up front and my rear point is on the bottom longerons tied into the step support.
I guess all three ways would work if you needed to pull the red handle.
Scott Laughlin
http://www.cooknwithgas.com/BRS.html
Gig Giacona
PostPosted: Thu May 08, 2008 7:05 am    Post subject: Re: Upper Engine Mount (BRS Style) Reply with quote
Scott, Does your front attach point connect with the bottom longeron?
cookwithgas wrote:
Patrick:
Scott Laughlin
W.R. "Gig" Giacona
601XL Under Construction
cookwithgas
PostPosted: Fri May 09, 2008 6:00 am    Post subject: Re: Upper Engine Mount (BRS Style) Reply with quote
Gig:
Yes. There is a stiffener attached under the fuselage here:
http://www.cooknwithgas.com/4_29_06_BRS_Underside.JPG
It is also attached to the firewall here:
http://www.cooknwithgas.com/2_19_05_Nosewheel.jpg
(See the two green stiffeners).
I'm sure there are many ways to accomplish the same thing. The rear harness also connects to the bottom longeron via the step reinforcement here:
http://www.cooknwithgas.com/5_3_06_BRS_Rear.JPG
Take care,
Scott.
