Changing the mag switches out for emag and pmag
nuckollsr(at)cox.net
PostPosted: Fri Mar 03, 2006 8:46 am    Post subject: Changing the mag switches out for emag and pmag Reply with quote
At 08:25 AM 3/3/2006 -0800, you wrote:
<frank.hinde(at)hp.com>
Not sure I understand the need for the test switch.
If I understand correctly to enter "Test mode" one simply needs to leave
the P lead grounded (off) and apply power, in this case turn on the
master. Of course now the whole ship is powered up but this seems a
fairly small inconvenience considering that timing is a pretty simple
affair.
Am I correct in my understanding here?
If you wire per Z-33 where powered support is available only
from the upper switch position for the purposes of confirming
a P-mag's internal power supply during pre-flight, then you
have no way to power up but ignition inactive (control lead
grounded) without the adding the third maintenance or test
switch switch.
