mike.schuler(at)sympatico Guest
Posted: Sat Apr 26, 2008 4:50 am Post subject: Engine mounts |
Is there any advantage using one type of dynafocal ring over another?
I plan to install an IO-360 into a Falco.
Mike Schuler
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
Posted: Sat Apr 26, 2008 7:36 am Post subject: Engine mounts |
Mike Schuler wrote:
Mike Schuler
Not sure what you're asking. The ring has to fit the engine. Type 1 is
by far the most common; type 2 was used on a few twins that had extended
hub props to streamline the engine nacelles better. The difference is
the point within the engine where the angles of the mounting bolts
converge to a point. It's supposed to be at the cg of the engine/prop
assembly.
The 'ears' on the engine are cut differently for the type 1 & type 2 mounts.
If you're buying a used engine, you *might* stumble upon an engine that
came off a twin with type 2 ears, but they are relatively rare. If
you're buying new, you'd probably have to beg to get one.
As an example of how rare they are, Van's A/C no longer supplies type 2
mounts for their kits, & they probably sell more Lyc powered kits than
all the other kit makers combined.
Does that help?
