nuckolls.bob(at)cox.net Guest
Posted: Thu Apr 24, 2008 8:36 am Post subject: Hope someone can point me in the right direction for troub |
At 11:10 PM 4/23/2008 -0400, you wrote:
| Quote: | I have come upon a problem. My plane is wired per Z-19 with two
batteries. Everything has been working fine. A couple of days ago, I
started the installation of my radios. To do so, I had to lean my panel
forward to gain access to the back.
When I next started the engine, I could hear what sounded like a loose
strap blowing and hitting against the bottom of the plane. I have since
found that this sound is caused by one of the solenoids making a clicking
noise. This sound would go away if I turned the alternator off, but the
alternator was outputting power when it was on. The next day, I found
that I could not get the alternator to output power at all. But&the
clicking sound was gone!
I removed both the alternator and voltage regulator and had them
checked. Both are working&Just not on my plane!
I am suspicious that I either have a hot wire loose or a ground has come
off. Does it sound to any of you like this could be the problem?
I will check for that tomorrow, but then I will be completely out of ideas
as to what to try.
Maybe someone can help here?
You're faced with the classic troubleshooting problem.
There are lots of places where a gross disconnect
can occur to produce the symptoms you cite. Fortunately
it's not an intermittent problem so your aiming at
moving target. Sorry I cannot be more specific.
