bakerocb
Posted: Mon Apr 21, 2008 3:13 am Post subject: Encoding Altimeter |
4/20/2008
Hello Anonymous, You wrote:
1) "You seem to be saying that the only practical way to meet the
requirements is to use a TSO'd source for the altitude information the
transponder is transmitting."
That is close. Here is how I would phrase it: "At present the only practical
way to be in compliance with FAR Section 91.217, Data Correspondence Between
Automatically Reported Pressure Altitude Data and the Pilot's Altitude
Reference, is to use a TSO'd equipment source for the altitude information
the transponder is transmitting."
2) "That, of course, would eliminate valuable functionality of many
non-TSO'd electronic EFISs including the serial output to the transponder."
Specifically, the serial altitude data output to the transponder from a non
TSO'd altitude encoder within an EFIS would not, at present, be in
compliance
with either 91.217 (b) or (c).
3) "Clearly, that isn't happening in the real world. These are selling
well."
Correct.
4) "Are you against that?"
Not at all. Here are my positions:
A) People should make informed decisions.
B) If I can provide accurate information to people that will permit them to
make informed decisions I should do so.
C) The decisions that those people make, after I have given them the best
information that I have available, is theirs to make, not mine. The risks
that they chose to take, or not take, are theirs, not mine.
D) Most of the EFIS available to the amateur built community represent a
significant improvement in performance, reliability, and safety over
previously available flight instrument technology.
E) Most of the EFIS available to the homebuilt community contain a non-TSO'd
altitude encoder that is superior in performance, reliability, granularity,
and accuracy over altitude encoding equipment that was manufactured to
versions of TSO-C88 prior to TSO-C88b.
F) Amateur built experimental aircraft have flown thousands of hours using
EFIS with non-TSO'd altitude encoders feeding their transponders with no
apparent problems.
G) Hundreds of amateur built experimental airplanes are under construction
using EFIS containing non-TSO'd altitude encoders.
H) The FAA should recognize and accept the real world conditions described
in D, E, F, and G above.
I) The best way for the FAA to accept the real world conditions described in
D, E, F, and G above is to interpret the tests required by FAR Secs 91.411
and 91.413 (as appropriate) as fulfilling the requirements of FAR Sec 91.217
(b).
J) My initial attempts to accomplish H and I above with FAA HQ were met with
resistance and I ceased activity in this regard.**
K) If the FAA, and the people / entities who perform the tests required by
91.411 / 91.413, decided that every non-TSO'd altitude encoder in an EFIS
was not airworthy because it did not meet the requirements of either 91.217
(b) or (c) this decision would be a serious blow to the amateur built
community.**
L) I do not proactively broadcast the information in K above, but if someone
asks a specific question on this issue or posts a position that I know to be
in error I revert to my positions A and B above.
M) I am open to improvements or changes in my positions.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
**PS: The FAA decision makers who perpetrated the recent fiasco involving
hundreds of airline flights being canceled and thousands of people being
stranded over the issue of the exact spacing of electrical wire cable ties
in the landing gear wheel wells of airline aircraft are capable of such
thinking and actions.
Float Flyr
Posted: Mon Apr 21, 2008 7:01 am Post subject: Encoding Altimeter |
One factor to remember is the operation of the encoding altimeter. To send
the correct information it needs to be set at 29.92 in. hg.. That for all
intents and purposes means you would have to either turn off your Xpndr or
have a second altimeter for lower altitudes. The big deal is every one
reports altitude to the same reference and the system as a whole operates
within parameters.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
reichec
Posted: Mon Apr 21, 2008 2:34 pm Post subject: Encoding Altimeter |
What?
The code that the encoding altimiter sends out is the altitude when you set
the alitimiter to 29.92, thats called pressure altitude. No matter where
you set the altimeter, the encoder portion still reports the altitude as if
the thing is set to 29.92. That never changes. You twist the knob to set
your local atimiter setting so your dial reads zero when you are at sea
level or actual field elevation for you locale. The system is calibrated at
29.92 and certified as to scale error +/- 25 feet when the altimiter is
certified every 2 years. You dont need 2 altimeters. Setting the dial
anywhere you want on an encoding altimeter has no effect on the encoder
portion of the device. Some encoding altimeters have what is called a baro
pot to send altimeter setting info to certain autopilots. Anyhow. ATC
corrects the number that your encoder sends out to the transponder and then
out to ATC for local altitude changes in pressure. You dont need to do this
for them and I certainly hope none of you have been leaving your encoding
altimeters on 29.92 thinking that you are doing them a favor.
In fact I would discourage people from owning an encoding altimeter as the
are a maintenance nightmare in some cases. They are expensive to overhaul
and if it comes up at your 2 year inspection that either the altimeter half
or the encoder half is out of spec, it makes the whole thing unairworthy.
Its cheaper in the long run to stick with good certified altimeters like
United instrument and encoders like the trans-cal SSD120-30A.
ACK/narco/Ameri-king encoders are cheaply built and you get what you pay
for.
Charles Reiche
wgill10(at)comcast.net Guest
Posted: Mon Apr 21, 2008 8:05 pm Post subject: Encoding Altimeter |
OR...you could buy a Dynon and save even more during the IFR
recertification check. In fact, the avionics shops actually prefer the
Dynon due to their accuracy and simplicity.
Bill
bakerocb
Posted: Tue Apr 22, 2008 5:26 am Post subject: Encoding Altimeter |
4/22/2008
Hello Bill, Thanks for your input. You wrote:
1) "OR...you could buy a Dynon ........."
Since the Dynon units do not contain a TSO'd altitude encoder operating the
Dynon unit alone to feed a transponder in flight would presently leave one
in violation of FAR Sec 91.217 (as interpreted by FAA HQ). There are two
ways to approach this condition:
A) Purchase and install a separate TSO'd altitude encoder and use that
encoder to feed the aircraft's transponder.
B) Decide that violation of 91.217 is an acceptable risk and feed the
transponder from the non TSO'd altitude encoder contained in the Dynon unit.
2) ".....and save even more during the IFR recertification check."
My local avionics shop charges a flat fee for the FAR Sections 91.411 and
91.413 required testing. This fee has been the same no matter whether I do
the labor of removing and reinstalling the altimeter and TSO'd altitude
encoder, for bench testing and any adjustments needed prior to the airplane
side testing, or they do that labor. (By the way, four years ago that flat
fee was $150, now it is $300.)
3) "........the avionics shops actually prefer the Dynon due to their
accuracy and simplicity."
I hope that the avionics shops continue this practice without any regard for
what FAR Sec 91.217 says.
4) ".......the avionics shops actually prefer the Dynon due to their
I wonder about the complexity of removing and reinstalling an EFIS from the
airplane compared to the complexity of removing and reinstalling an
altimeter and separate TSO'd altitude encoder should any bench testing and
adjusting be needed.
A) Maybe EFIS removal and reinstallation is no big deal, but I envision a
bunch of connections, particularly if it is the type of EFIS that also
includes displaying engine performance parameters.
B) Maybe the EFIS's have no means of local avionics shop adjustment.
C) Maybe the EFIS's would never need adjustment.
D) What has been the experience of EFIS operators that have actually been
through FAR 91.411 and 91.413 checks, as appropriate, after flying for at
least two years?
Would any EFIS owners and operators care to comment on these points?.
Time: 09:05:34 PM PST US
Subject: RE: Encoding Altimeter
Bill
reichec
Posted: Tue Apr 22, 2008 2:06 pm Post subject: Encoding Altimeter |
I have no experience with the dynon other than I want my friend to put one
in his rv7. But I can tell you that in installations such as this and like
the G1000, its easier to certify devices in the airplane rather than
removing them so you can be using whatever its readout is to certify it. I
have run across one GDC 74A (Garmin g1000 air data computer) that failed a
test point just slightly out of spec but garmin allows us to recalibrate and
electrically slide the scale so everything is within spec all the way up.
Remember that down low the tolerance is +/- 20 feet for altimeter
certification and up over 20k its well over +/- 100 feet. Mechanical
altimeters can and do sway their actual reading all over the place up at
altitude, and generally the air data computer tpye devices are pretty darn
close.
YMMV
Charlie
Posted: Tue Apr 22, 2008 5:54 pm Post subject: Encoding Altimeter |
I have the Dynon and a mechanical altimeter...both remained in the plane
for testing and both altimeters met the requirements. However, the
transponder was removed for bench testing.
Bill
