Fox5flyer Guest
Posted: Tue Apr 22, 2008 3:04 am Post subject: Woes of high speed taxiing |
Ground loops and the damage caused from them during high speed taxi is a
very old and sad story on this list. Many folks have spent several years
building their airplane and in minutes it's back in the shop for another
year of repairs or get disgusted and sell what's left of the airplane.
The merits and woes of high speed taxiing is a topic that has come and gone
several times here, usually after some poor soul happened to lose control
during the process. One of the problems with a KF, especially the early
models, is that it can easily get airborne in ground effect long before one
has control authority which can easily result in loss of control.
Generally, the consensus was to not do any high speed taxiing at all because
it proves nothing and only offers an opportunity to cause damage. Just go
out, taxi around for awhile keeping the speed slow and safe, taxi back to
check things out under the hood one last time, and if all is well and the
conditions are favorable, go back out and firewall it. Most of us have
gotten away with high speed taxiing, but many others have not.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
- Joseph Joubert
At 06:49 PM 5/20/2008, you wrote:
>My first high speed taxi run.....it got away from me.
>It started to fish tail and and I must have pushed too hard on one pedal.
The only really useful piece of advice I got on high speed
taildragger work was to never press and hold a rudder pedal, but rather to
stab at it, look at the results, then stab again as necessary. This tends
to keep you away from pilot induced oscillation, since your response
frequency is much higher with the stab than with the push and hold. As you
get better the stabs get smoother and may eventually disappear altogether,
but I find I still do it for major excursions.
Guy Buchanan
San Diego, CA
brucejolene(at)iowateleco Guest
Posted: Tue Apr 22, 2008 4:04 am Post subject: Woes of high speed taxiing |
After repairs, I'm going to seek a qualified instructor before I do
anything.
Would an examination of the wing by a mechanic be warrented?
Guy Buchanan
Posted: Tue Apr 22, 2008 8:46 am Post subject: Woes of high speed taxiing |
At 05:01 AM 4/22/2008, you wrote:
| Quote: | | After repairs, I'm going to seek a qualified instructor before I do anything. |
Good idea. Also, reading Stick and Rudder and Ed Downs' Kitfox Pilot's Guide are good. Be wary, though. Few instructors have the experience of anything as squirrelly as a Kitfox. I know our local Citabria CFI expert nearly choked on her chewing gum the first time she flew a IV. (She is also a Cub expert.) Look for someone with time in a Lucsombe or Kitfox/Avid/Highlander/etc.
| Quote: | | Would an examination of the wing by a mechanic be warrented? |
Did it touch the ground? If so, definitely.
By the way, I am of the pro-high speed taxi set. I understand you can survive a long time wrestling it into the air as soon as possible, and then keeping it off the ground as long as possible via three-pointers, but I think it rather limits your capabilities. (I suppose that, over time, you'll get more used to the pedals and will be able to do wheel landings and the other things that require high speed taxi capabilities, but how will you know?) I suppose the best idea would be to learn to high-speed taxi on turf or dirt, where you can slide around a little, then transition to the hard.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
n85ae
Posted: Tue Apr 22, 2008 10:00 am Post subject: Re: Woes of high speed taxiing |
Learn to tail up taxi your favorite taildragger. Then take the fox out and
practice the same thing. You won't get airborne if you keep the stick
forward.
My first two passes in my Kitfox were eye openers as I was NOT used to
the rudder effectiveness. SO I'm glad I practiced a bunch of tail up runs
in it first before I ever flew it.
I also had a 6500 ft. runway, wide enough to land a 747 on for practice
as well which made directional control not so critical as well. I just went
early in the morning and amused the controllers with my repeated
requests to fast taxi down the ruunway.
I'm not an expert, but my advice would be to get used to flying it on the
ground before you try to land it from the air ...
Jeff
clint_bazzill(at)hotmail. Guest
Posted: Tue Apr 22, 2008 10:09 am Post subject: Woes of high speed taxiing |
You are so right. I have over 1300 hours on my Model IV. I let one person fly my aircraft, didn't know him from Adam but met him at Reid Hillview Airport. He said he owned several Lucsombe's. After taking off he flew around the area as I was pretty new in that area. He did a great job flying and I asked him if he wanted to land it. He said sure, I fly from the right seat so he was in the left. He did a great job of landing and my only comment was he flaired a little hot on speed, he said that he wanted to feel the aircraft in ground effect before he got it too slow.
Clint
[quote] Date: Tue, 22 Apr 2008 09:38:52 -0700
Subject: Re: Woes of high speed taxiing
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. | Quote: |
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
| [b]
msm_9949(at)yahoo.com Guest
Posted: Tue Apr 22, 2008 11:34 am Post subject: Woes of high speed taxiing |
Hey! Watch it fella. Don't you be calling my Fox "squirrelly!" She's "nimble!" But if what you mean is that Kitfoxes don't handle like Cubs or Citabrias, you're absolutely right. Ed Down's calls it "high performance" and I agree, at least to the extent that characterization can be applied to an airplane that cruises at 70 mph.
I tried high speed taxiing, should have gone ahead and flown. IMHO, it puts the airplane in the most difficult part of the performance envelope and should be avoided by novices. I ground looped . . . thank God for those droopy "wing tip protectors."
By the way, I am of the pro-high speed taxi set. I understand you can survive a long time wrestling it into the Be a better friend, newshound, and [quote][b]
Michel
| Quote: | From: n85ae [n85ae(at)yahoo.com]
I just love to land on an airfield with tower, on the numbers, then taxi with the tail up to the taxiway I am asked to exit. I know that they watch me from the tower and my ego feels good! But, of course, it requires practice.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
_________________ Kitfox 3 - Jabiru 2200 |
peteohms
Posted: Tue Apr 22, 2008 2:05 pm Post subject: Woes of high speed taxiing |
While the Kitfox is defiantly "nimble". I flew my III home from Buckeye, Az to where I keep it in Las Cruces, NM (except the last 60 miles). I had no previous time in a Kitfox except a little hands on in a Kitfox IV thanks to a gentleman in the Phoenix area (no takeoffs and landings). I had 20 hrs recent experience, 8 of which was in taildraggers. 28 years I had not flown. I had about 20 total hours tail dragger time at the time I lifted off at Buckeye. 2.7 hours of my recent time was in a Cessna 140. I think it is way harder to fly the 140. I feel I am not qualified to fly a 140. My theory when I bought my Kitfox was to take off with no high speed taxiing practice. I felt that If I was to ding the plane up I should fly it as close to my home as possible so the parts would at least be closer to home. When I took off I was not getting full power due to prop adjustment so it took more runway than I planned. I got a little squirrelly on the runway but was finally airborne before it got too bad. My first Kitfox III landing was 2 hrs after taking off. I landed at Marana Regional, west of Tucson, AZ to gas up just to see how much fuel I was using. My landing was 3 or 4 bounces and got a swerve or two on roll out. A friend said I should log each of those bounces. When I took off from Marana I concentrated on what I was doing and made a good takeoff (no swerves). I wasn't sure if my transponder was working so before I left Marana I called Tucson approach on the phone and asked if they would clear me through class C airspace. The controller was cool and when I called after takeoff he had me squawk 0401 (or some such) then he had me turn a heading of 180. He said my transponder was working but showed some other code. I flew the remaining 3.6 hours to Deming, NM at 7500 ft +/- 500' because of thermal activity. I had planned to go all the way to Las Cruces, NM but it was starting to get dark so I made a pretty good landing in Deming, NM. I believe some of the reason I was able to fly the Kitfox is because I made some rudder pedals for Microsoft Flight simulator and spent a bunch of time practicing. That's my story. May have been the crazy way to go but it was a Great Adventure.
Pete
Kitfox III N73BH 912 ul
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
Posted: Tue Apr 22, 2008 2:45 pm Post subject: Woes of high speed taxiing |
What did you do to check the wing for damage? I have the droop tips too.
How did you repair the tip?
Bruce
Good advice thanks.
Posted: Wed Apr 23, 2008 5:13 am Post subject: Woes of high speed taxiing |
Hi Bruce.
The loop was on grass and my wingtip barely touched. The incident was more of an embarrassment than anything else. I have (unopened) inspection holes near the wingtips but did not think it warranted to cut open for inspection. In the end, all I had to do was clean up a little dirt and add touch-up paint to the tip (and to my ego).
I would think, though, that more serious damage to these tips would be easily reparable with an inexpensive fiberglass repair kit.
Bruce Jolene <brucejolene(at)iowatelecom.net> wrote:
[quote] What did you do to check the wing for damage? I have the droop tips too.
Bruce
Float Flyr
Posted: Wed Apr 23, 2008 7:38 am Post subject: Woes of high speed taxiing |
It never hurts to have another party check out any repairs you make to your plane. When you find the instructor both of you should do an in depth walk around. Point out any place you may have worked on.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Guy Buchanan
Sent: Tuesday, April 22, 2008 2:09 PM
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
7.29 KB |
9453 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
akflyer
Posted: Wed Apr 23, 2008 8:21 am Post subject: Re: Woes of high speed taxiing |
[quote="msm_9949(at)yahoo.com"]Hi Bruce.
Bruce
I have done repairs to the wing tips using both fiberglass resin / cloth and thin CA used for R/C models. Both have held up well. The First repair was done by just wicking thin CA into the joint as the tips were starting to de-laminate at the trailing edge. This repair held up quite well until a gear failure led to a modified ground loop with a 1 1/2 ganier flip / twist... That repair called for serious fiberglass work, but nothing exotic.
I just completed repairs on the wing tips for my Avid that were damaged by the previous owner in a manuver pretty much inline with the above described event / ride my brother so graciously felt the need to share with me.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Posted: Thu Apr 24, 2008 3:47 am Post subject: Woes of high speed taxiing |
thanks.
