Vertical Stab (rudder) question???
Andrewlieser
PostPosted: Mon Apr 21, 2008 5:07 pm    Post subject: Vertical Stab (rudder) question??? Reply with quote
Hey everyone, I am looking for a bit of advice on my rib alignment for my rudder. I am getting ready to rivet my rudder "skeleton" together this weekend and noticed that my 3rd rib is approximately 1-2 mm off center. The lip of the rib actually is recessed a tad on one side and protrudes a tad from the spar on the other. This my be knit picky or it may not be but I am new at this and would like to know if this is within the tolerances of the design. I am learning a great deal about what methods get me the best results right now so I apologize if this is a dumb question. Thanks in advance,
Andrew Embarassed
Andrew Lieser
S/N 6-7045
http://websites.expercraft.com/andrewlieser
Ron Lendon
PostPosted: Mon Apr 21, 2008 7:31 pm    Post subject: Re: Vertical Stab (rudder) question??? Reply with quote
Pictures? WebSite?
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Andrewlieser
PostPosted: Mon Apr 21, 2008 8:09 pm    Post subject: Re: Vertical Stab (rudder) question??? Reply with quote
Sorry here is a picture taken tonight it is taken at very close range and looks slightly exaggerated because of the angle
Rib lip over spar lip measured to exactly 1mm over the spar lip.
 Filesize:  2.61 MB
 Viewed:  758 Time(s)
Andrew Lieser
S/N 6-7045
larry(at)macsmachine.com
PostPosted: Tue Apr 22, 2008 6:26 am    Post subject: Vertical Stab (rudder) question??? Reply with quote
Not a dumb question Andrew,
and you don't have to be embarrassed as we've all made minor mistakes.
The hazard is not correcting them when we see them.
I'd recommend you make adjustments that allow you to lay a yardstick or
such across the ribs to get them aligned. It may only take
drilling out the rivets, or clamping and drilling for the next size
rivet, or making the rib over. This would be a good time to learn the
art of
replacing a bad part with one built from scratch. It'll save you a lot
of money. The misalignment would probably be easily seen, so
I'd go for the fix and hold onto your sense of what's right. Go for it.
Andrew [Embarassed]
Andrew Lieser
http://forums.matronics.com/viewtopic.php?p=178323#178323
bryanmmartin
PostPosted: Tue Apr 22, 2008 4:41 pm    Post subject: Vertical Stab (rudder) question??? Reply with quote
That much mis-alignment will probably be noticeable in the finished
rudder. Re-clamping and carefully drilling out the holes for A5 rivets
will probably fix the problem. If not, making a new rudder rib isn't
very difficult, its just a two straight bends.
Andrew [Embarassed]
Andrew Lieser
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
Bryan Martin
do not archive.
