Jab 2200 question
reinkings(at)comcast.net
PostPosted: Sat Apr 19, 2008 4:04 pm    Post subject: Jab 2200 question Reply with quote
Quick question: I'm not too optimistic about this but what kind of
performance would I expect to see with the Jab 2200 on a max loaded
601XL? I'll stand back....
jetboy
PostPosted: Sat Apr 19, 2008 9:21 pm    Post subject: Re: Jab 2200 question Reply with quote
the XL was designed for 100 hp or more engines in mind, specifically Jabiru 3300 and Rotax 912S. If you only have 80hp, better stick with the basic 601UL or 601 model that are set up for that range. If you are yet to buy the engine, the 3300 is not much more $ than a 2200 anyway.
I can't answer with direct experience, but expect a 601XL would be unsatisfactory with any 80hp direct drive engine, be it VW, EA81 or 2200.
Ralph
Ralph - CH701 / 2200a
larry(at)macsmachine.com
PostPosted: Sun Apr 20, 2008 6:43 am    Post subject: Jab 2200 question Reply with quote
Hi John,
Max loading is the variable here. If the plane were built light to
begin with contrary to current trends, the engine would probably perform
well, not great, but o.k.
With a single header tank, two people and 40 lbs baggage, starting with
an empty weight less than 650 lbs, you'd be surprised at the economy and
distance you'd be
able to go. I bet someone has already done it out there.
PostPosted: Sun Apr 20, 2008 6:50 am    Post subject: Jab 2200 question Reply with quote
Ralph,
Several Stratus and Ram EA-81s are being put on XLs of late as they
offer not less than 100 hp and performance in line with or better than
the 0-200
class engines. They cost much less to buy and can operate on 87-octane
car gas or 100LL.
Ralph
amyvega2005(at)earthlink.
PostPosted: Sun Apr 20, 2008 7:45 am    Post subject: Jab 2200 question Reply with quote
you can put an engine smaller than 90 hp on the XL. Just check the weights when flying. CHeck with Zenith and the Heintzs, there are XLs flying just fine with less than 100 hp. Frankly I have a 3300 Jab and I hardly use full power.
Juan
PostPosted: Sun Apr 20, 2008 7:47 am    Post subject: Jab 2200 question Reply with quote
thats not entirely correct, if that is the case a O 200 would not be n the the XL as it's max HP rating is 95 hp. there have been less HP egnies on XLs and depending on weight issues, work fine. JUst do the research. 2200 may work but you may have long take offs.
Juan
PostPosted: Sun Apr 20, 2008 7:50 am    Post subject: Jab 2200 question Reply with quote
see attached picture of 2200 Jabiru on XL.
Juan
 Filesize:  43.61 KB
 Viewed:  482 Time(s)
dougsnash
PostPosted: Sun Apr 20, 2008 8:02 am    Post subject: Jab 2200 question Reply with quote
Notice Ralph said "Direct Drive". The Ram and Stratus
engines have re-drives.
Do not archive.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
Ralph,
of late as they
with or better than
the 0-200
car gas or 100LL.
jetboy wrote:
<sanson.r(at)xtra.co.nz>
> Ralph
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
