Wiring NL starter help
VHMUM(at)bigpond.com
PostPosted: Fri Apr 18, 2008 12:58 pm    Post subject: Wiring NL starter help Reply with quote
Guys I am now stuck. I have the NL starter and also wired the plane as per
Vans wiring kit which I now know is wrong for this starter. I contacted Vans
and they are not interested in helping as not the starter they supply.
Can somone have a look at the skytec diagram and give me an idea what wires
to change. Ofcourse if you have not used Vans diagram you will not know the
difference.
Vans starter relay has 4 terminals and Skytec diagram has 3. Also Skytec has
1 wire going to the starter not 2.
http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg
Luckily John Jessen pointed this out
regards Chris
msausen
PostPosted: Fri Apr 18, 2008 1:26 pm    Post subject: Wiring NL starter help Reply with quote
Chris, what chapter page is the Van's diagram?
PostPosted: Fri Apr 18, 2008 1:41 pm    Post subject: Wiring NL starter help Reply with quote
OP37 -13
Kellym
PostPosted: Fri Apr 18, 2008 9:26 pm    Post subject: Wiring NL starter help Reply with quote
I tend to think you have the wrong relay. The starter relay is normally
an intermittentduty model, with 3 terminals as shown in the Skytec
diagram. Master relays normally have 4 terminals. I note that the
pictures in the Spruce catalog are also reversed. Sad
Chris and Susie McGough wrote:
<VHMUM(at)bigpond.com>
per Vans wiring kit which I now know is wrong for this starter. I
contacted Vans and they are not interested in helping as not the
wires to change. Ofcourse if you have not used Vans diagram you will
not know the difference.
Skytec has 1 wire going to the starter not 2.
regards Chris
Kelly McMullen
KCHD
jesse(at)saintaviation.co
PostPosted: Sat Apr 19, 2008 4:32 am    Post subject: Wiring NL starter help Reply with quote
In my experience the master has 3 contacts and the starter has 4. Ground
closes the master and power closes the starter.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
352-427-0285
> regards Chris
rv10builder(at)bellsouth.
PostPosted: Sat Apr 19, 2008 11:22 am    Post subject: Wiring NL starter help Reply with quote
I too have the 149-NL starter (that came with my TMX-540) and it is
wired per Van's Lightweight Starter Circuit with the "I" terminal
connected to the smaller stud (jumper removed). It's working just fine...
Brian Sutherland
Nashville, TN
N104BS
13.5 hours in Phase 1
regards Chris
PostPosted: Sat Apr 19, 2008 12:33 pm    Post subject: Wiring NL starter help Reply with quote
Thanks Brian if it was not for this list I would had a stuffed starter.
Enjoy your flying.
regards Chris
Mike Whisky
PostPosted: Sat Apr 19, 2008 12:37 pm    Post subject: Re: Wiring NL starter help Reply with quote
I am not sure if I can add help or more confusion here. But I wrote this question to SkyTec since I wanted to know what to do with my 149 NL Starter which came with my the TMX IO-540.
Michael,
Per that page, "All Sky-Tec NL starters must be wired per diagram "B" below as there is no active "S" terminal. The small, "S" terminal on the NL model starter is used to switch the starter from 24V (jumper wire removed) to 12V (jumper wire installed) operation and cannot be used to activate the starter."
So yes, assuming you are running this thing on 12V, you will need to install the jumper.
It is confusing.
- Rich
Rich Chiappe
Sky-Tec
800-476-7896
richc(at)skytecair.com
www.skytecair.com
Quoutattion end:
I read here to keep the jumper on!
Do I miss
something?
Michael
RV-10 builder (flying)
#511
wcurtis(at)nerv10.com
PostPosted: Sat Apr 19, 2008 1:09 pm    Post subject: Wiring NL starter help Reply with quote
The diagram he is referring to is here: http://www.skytecair.com/images/NL%2012V%20Installation%20Wiring_1100.jpg
Also attached. My TMX-IO540 also came with the NL starter and I wired it per this diagram.
William
http://nerv10.com/wcurtis/
 Filesize:  89.69 KB
 Viewed:  540 Time(s)
PostPosted: Sat Apr 19, 2008 1:16 pm    Post subject: Wiring NL starter help Reply with quote
From Skytec
Sky-Tec repurposed the S-Terminal functionality on NL model starters to
serve as a means of switching the starter between 12V and 24V operation.
Because of this, ALL NL STARTER INSTALLATIONS MUST BE WIRED ACCORDING TO THE
CERTIFIED AIRCRAFT WIRING DIAGRAM BELOW - NO EXCEPTIONS!
I noticed on the starter when I put the jumper back it says someting like
jumper for 12 volt operation. So if that jumper is used it becomes a 24 volt
starter. I must have had a coeliac moment when I first removed it.
regards Chris
PostPosted: Sat Apr 19, 2008 1:25 pm    Post subject: Wiring NL starter help Reply with quote
Woops missed a critical word .....
From Skytec
THE
jumper for 12 volt operation. So if that jumper is not used it becomes a 24
volt
regards Chris
PostPosted: Sat Apr 19, 2008 1:45 pm    Post subject: Wiring NL starter help Reply with quote
I think you have it backwards. When the junper is ON, it's a 12 volt starter; when the jumper is OFF it is a 24 volt starter.
William
PostPosted: Sat Apr 19, 2008 1:55 pm    Post subject: Wiring NL starter help Reply with quote
This is interesting. My starter relay has FOUR terminals and came with a tag that said "If original has 3 terminals DO NOT use this "I" terminal."
William
PostPosted: Sat Apr 19, 2008 1:56 pm    Post subject: Wiring NL starter help Reply with quote
Yep I sent another email thanks
Chris
msausen
PostPosted: Sat Apr 19, 2008 3:07 pm    Post subject: Wiring NL starter help Reply with quote
Think you got the wrong guy attached to the quote below William. That was Brian Sutherland that said that, not me.
Michael
msausen
PostPosted: Sat Apr 19, 2008 3:08 pm    Post subject: Wiring NL starter help Reply with quote
For now. Smile
Michael
PostPosted: Sat Apr 19, 2008 6:49 pm    Post subject: Wiring NL starter help Reply with quote
Sorry about that. Getting confused as to who is saying what.
William
PostPosted: Sun Apr 20, 2008 5:38 am    Post subject: Wiring NL starter help Reply with quote
And I should have probably added the statement: Prior to flying Sunday
I'll be pulling the cowl and disconnecting the "I" lead and
re-installing the jumper. The reason I haven't had a problem is that
12V is still being supplied to the 12/24V stud via the "I" lead rather
than the jumper. I may be wrong but my guess is that Van's diagram for
the LS provided a safeguard against a stuck starter relay in that the
starter also must see 12V via the S/I leads coming from the starter
switch. Obviously this is problem for the NL as a stuck relay would put
the starter in 24V mode and likely result in damage.
Brian Sutherland
Nashville, TN
N104BS
fine...
Brian Sutherland
Nashville, TN
N104BS
> as per Vans wiring kit which I now know is wrong for this starter. I
> regards Chris
