tdawson-townsend(at)auror Guest
Posted: Fri Apr 18, 2008 6:04 am Post subject: 12 "cigarette" receptacle |
Check this out. I didn’t really like the bulky cigarette-type power receptacles from Spruce or elsewhere (commonly with a flange on both sides for screw mounting), so I went to the aviation department at West Marine and found this one by Marinco. As you can see, it mounts with a screw-on ring in the back, so you’ve only got the diameter of the receptacle itself showing in front. There is an optional front flange if you want to use it. It also has a nice-sealing cap, being a marine product . . .
I think it was $17.99 at my local West Marine. You landlubbers will have to go on their web site, if interested.
TDT
40025
Wings going on soon!
From: Dawson-Townsend [mailto:yooper(at)alum.mit.edu]
Sent: Friday, April 18, 2008 1:35 AM
To: Dawson-Townsend,Timothy
Subject: P1000230.JPG
397.78 KB |
411 Time(s) |
Posted: Fri Apr 18, 2008 6:38 am Post subject: 12 "cigarette" receptacle |
Stein sells a really nice one for less than that, I think. It has a metal back ring that screws on. Very nice to work with (the receptacle and, as everybody already knows, Stein).
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Apr 18, 2008, at 9:58 AM, Dawson-Townsend,Timothy wrote: | Quote: | Check this out. I didn’t really like the bulky cigarette-type power receptacles from Spruce or elsewhere (commonly with a flange on both sides for screw mounting), so I went to the aviation department at West Marine and found this one by Marinco. As you can see, it mounts with a screw-on ring in the back, so you’ve only got the diameter of the receptacle itself showing in front. There is an optional front flange if you want to use it. It also has a nice-sealing cap, being a marine product . . .
TDT
40025
From: Dawson-Townsend [mailto:yooper(at)alum.mit.edu (yooper(at)alum.mit.edu)]
<P1000230.jpg>
robin1(at)mrmoisture.com Guest
Posted: Fri Apr 18, 2008 6:46 am Post subject: 12 "cigarette" receptacle |
I also didn’t care for any aviation 12V receptacle I could source and the best looking one I could find was on one a 2008 Honda (CRV). Most newer Honda’s used the same receptacle with a rectangular spring loaded cover plate and a nice 12V embossed on the face plate. I think I paid $20.00 each delivered from an online automotive supply house.
Sorry no photos as I am traveling.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dawson-Townsend,Timothy
Sent: Friday, April 18, 2008 6:59 AM
Subject: FW: 12 "cigarette" receptacle
TDT
40025
gommone7(at)bellsouth.net Guest
Posted: Fri Apr 18, 2008 8:12 am Post subject: 12 "cigarette" receptacle |
Bldgrv10450(at)comcast.ne Guest
johngoodman
Posted: Fri Apr 18, 2008 6:19 pm Post subject: Re: 12 |
Funny that a cigarette lighter defines a standard. Sort of like the 4 feet 8.5 inches of a railroad track....
_________________ #40572 Phase One complete in 2011 |
snyderbd888(at)sbcglobal. Guest
Posted: Sat Apr 19, 2008 6:16 pm Post subject: 12 "cigarette" receptacle |
Are most of the parts plastic on that power receptacle? Thanks.
Bruce
40353
Sent: Friday, April 18, 2008 9:59 AM
TDT
40025
