bakerocb
Posted: Tue Apr 15, 2008 4:42 am Post subject: Questions on avionics |
4/15/2008
Hello Bruce, You wrote:
"1. What does it mean to "cage" an attitude indicator?"
Some attitude indicators have a mechanical means to lock the gyro gimbals so
that the gyro gimbals are held rigidly to the instrument case. This can
serve two functions:
A) It can save wear and tear on the gyro if you are going to do some
aerobatic manuevering and don't want the gyro to be moving around
extensively as it tries to always show the proper aircraft attitude.
B) If the gyro has tumbled and one wants to erect it again to a proper
attitude one can put the airplane in a level attitude, cage and then uncage
the gyro, and it will then start indicating properly a level attitude from
that new starting point.
"3. Is purchasing a separate encoder necessary?.....I see some avionics
vendors packaging
in a separate encoder but don't really understand why."
They are doing this because the altitude encoder in almost all of the EFIS
being sold to the amateur built community are not TSO'd and therefore do not
comply with FAR Sec 91.217 copied here:
"91.217: Data correspondence between automatically reported pressure
altitude data and the pilot's altitude reference.
No person may operate any automatic pressure altitude reporting equipment
associated with a radar beacon transponder-
(a) When deactivation of that equipment is directed by ATC;
(b) Unless, as installed, that equipment was tested and calibrated to
transmit altitude data corresponding within 125 feet (on a 95 percent
probability basis) of the indicated or calibrated datum of the altimeter
normally used to maintain flight altitude, with that altimeter referenced to
29.92 inches of mercury for altitudes from sea level to the maximum
operating altitude of the aircraft; or
(c) Unless the altimeters and digitizers in that equipment meet the
standards of TSO-C10b and TSO-C88, respectively."
So you can see that an altitude encoder in use must meet either be TSO'd or
comply with subparagraph (b) above.
Some people think that the encoder, altimeter, and transponder checks
required every two years by FAR Sections 91.411 and 91.413 meet the
requirements of subparagraph (b) above, but that is not the present position
of FAA HQ. They prescribe a more elaborate, almost impossible to accomplish
test.
So one solution to the problem created by having an EFIS with a non TSO'd
altitude encoder installed in your airplane is to install and use a separate
TSO'd altitude encoder.
If you want to read more on this subject go to the Matronic aeroelectric
list archive and search for 91.217.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
PS: Some EFIS manufacturers will claim that their altitude encoder "meets
TSO standards". Note that a claim of "meeting TSO standards" and being
actually TSO'd are not the same thing. Ironically some of these non TSO'd
altitude encoders are actually superior in performance and technology than
the standards required by the TSO. The EFIS manufacturers have chosen not to
obtain actual TSO approval for their altitude encoders because of the
expense and bureaucratic burden involved.
| Quote: | Time: 05:57:43 PM PST US
Subject: Questions on avionics
Hi all,
I have a couple of basic questions I don't understand well:
1. What does it mean to "cage" an attitude indicator? I've never flown a
plane
that has had this option but I see it on some I'm considering for my
homebuilt.
2. I want a light IFR panel and have read some things about Mode S
transponders.
Is there any advantage to having one over a Mode C other than the TIS
capability?
3. Is purchasing a separate encoder necessary? I was planning on putting
a Blue
Mountain EFIS One in my plane (please no negative comments as I'm already
committed),
a Garmin 430W with a GI-106A CDI, and a Garmin 327 transponder (pending
the answer to number 2 above) in my plane. I see some avionics vendors
packaging
Thanks for your help
Bruce Peters
RV9A, Fuselage
Bakersfield, CA
BobsV35B(at)aol.com Guest
Posted: Tue Apr 15, 2008 8:35 am Post subject: Questions on avionics |
Good Morning OC,
Nice answer to the question asked, but may a I add a bit?
If you intend to do aerobatics and intend to cage the gyros to avoid wear, it is best to shut of the air first so that the gyro is not spinning while it is locked up. While being caged will keep it from banging the stops, the bearings will be exposed to abnormal wear by the gyro being restrained. If the air is turned of after the gyro is already spun up, a good gyro will take about thirty minutes to get stopped. Best to shut off the air before the engine is started.
There is no real good solution, only methods of mitigation.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 4/15/2008 7:47:34 A.M. Central Daylight Time, bakerocb(at)cox.net writes:
aerobatic maneuvering and don't want the gyro to be moving around
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
frank.hinde(at)hp.com Guest
Posted: Tue Apr 15, 2008 9:20 am Post subject: Questions on avionics |
Really the best way to do aerobatics is to fit a glass EFIS...I regularly (like every flight) wring out my RV and the Dynon scratches its head sometimes but returns to normal like clockwork. Same for the TT autopilot.
I noticed that Kathy Hirtz does her airshow routines in her Wolf Pitts and has a Dynon D180 installed..And there is not a more radical aerobatic machine out there.
Its about time the mechanical gyros went the way of the Dodo...As long as your airplane is experimental of course.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Tuesday, April 15, 2008 9:29 AM
Subject: Re: Questions on avionics
Good Morning OC,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
Posted: Tue Apr 15, 2008 9:58 am Post subject: Questions on avionics |
Good Afternoon Frank,
Absolutely and totally agree!
The problem is that the FAA puts so many hurdles in the way that by the time the stuff gets approved, the cost is way above what normal folks can afford.
Right now, only home builders have any chance of going with modern equipment.
I do realize that most FAA folks are just as enthusiastic aviators as are the rest of us, but they are hamstrung with rules that are forced on them by the Bureaucracy and that Bureaucracy is driven by the Congress critters who do nothing for us at all.
All they care about is having someone to blame when anything goes wrong.
I recently had the pleasure of flying some twenty-four hours in a Legend Cub that was equipped with the Dynon 180. I certainly did not learn how to use all of it's many capabilities, but what I saw, was great.
I have been following Jim Younkin's very rapid development of flight instruments and autopilots. I love his attitude toward the FAA, but it doesn't help we who fly primarily certified aircraft.
Unless someone who is willing to argue with the FAA manages to steal some of his ideas and get the FAA approval for us to use that much better stuff, we are stuck with 1920s technology.
Had the FAA been in charge in 1920 we would not yet have mechanical gyros, let alone anything better!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 4/15/2008 12:22:40 P.M. Central Daylight Time, frank.hinde(at)hp.com writes:
| Quote: | Really the best way to do aerobatics is to fit a glass EFIS...I regularly (like every flight) wring out my RV and the Dynon scratches its head sometimes but returns to normal like clockwork. Same for the TT autopilot.
Frank
Bill Denton
Joined: 10 Jan 2006 Posts: 97 Location: Chicago, IL USA
Posted: Tue Apr 15, 2008 10:26 am Post subject: Questions on avionics |
Bob…
Aspen Avionics http://www.aspenavionics.com/ recently received the TSO and the AML STC for their glass PFD.
$6,000 + install for a VFR unit; $10,000 + install for an IFR unit. Not really cheap, but not as pricey as Garmin or Avidyne. So you guys flying TC aircraft can get some of the toys without totally busting the bank.
And no more spinning gyros!
Thanks!
Bill Denton
bdenton(at)bdenton.com
Sent: Tuesday, April 15, 2008 12:56 PM
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Frank |
| Quote: | | http://www.matronics.com/Navigator?AeroElectric-List | 0123456789
Posted: Tue Apr 15, 2008 10:43 am Post subject: Questions on avionics |
Good Afternoon Bill,
It's getting there!
I do know that they are now saying the entire year's production is already spoken for.
Last person I spoke to said they figure the installation they ordered would be at least twenty grand installed. Better than a Garmin, but still a lot of money. If it was an automotive device, produced in China, and used on a Toyota it would be fifty bucks!
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 4/15/2008 1:29:02 P.M. Central Daylight Time, bdenton(at)bdenton.com writes:
Bob…
Thanks!
Bill Denton
Posted: Tue Apr 15, 2008 11:01 am Post subject: Questions on avionics |
Yes I feel for the certified guys...The last IFR proficiency ride i took my instrument student friend and he kept babbling something about "what about the precession"....I said "We're not in a precession, we're flying by ourselves!"
Nice to hear from you again Bob....And you were right, learning IFR in a fast airplane is not hard at all...learning in one that happens to be aerobatic its a bit of a handful though..
Frank RV7a
Sent: Tuesday, April 15, 2008 10:56 AM
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Frank
ics.com
rampil
Posted: Wed Apr 16, 2008 3:25 am Post subject: Re: Questions on avionics |
Re: TSO and altimetry sources
There is no requirement for TSO in owner built aircraft. As I said
previously, there is only a performance requirement.
Part 23 is a separate issue.
bakerocb
Posted: Thu Apr 17, 2008 5:55 pm Post subject: Questions on avionics |
4/17/2008
Hello Ira,
1) You wrote: "There is no requirement for TSO in owner built aircraft."**
2) FAR SEC 91.217 Says:
"Data correspondence between automatically reported pressure
3) Please explain, with specific valid reference, why the phrase "No person
may ..." seen above would not apply to a person flying an amateur built
experimental aircraft.
4) You are correct that there are alternatives to using TSO'd equipment,
when such equipment is specifically required by a regulation, provided that
you can prove to the FAA's satisfaction that your alternative equipment is
acceptable to the FAA. Here is how you go about doing that:
FAR Sec. 21.609 "Approval for deviation.
(a) Each manufacturer who requests approval to deviate from any performance
standard of a TSO shall show that the standards from which a deviation is
requested are compensated for by factors or design features providing an
equivalent level of safety.
(b) The request for approval to deviate, together with all pertinent data,
must be submitted to the Manager of the Aircraft Certification Office for
the geographic area in which the manufacturer is located. If the article is
manufactured in another country, the request for approval to deviate,
together with all pertinent data, must be submitted through the civil
aviation authority in that country to the FAA."
Obtaining an approval for deviation is not a trivial task and none of the
manufacturers of non TSO'd altitude encoders contained in their EFIS units
have done so to my knowledge.
**PS: This statement is also not correct when it comes to the ELT installed,
if one is required by FAR Sec 91.207, in an amateur built experimental
aircraft.
Time: 04:30:41 AM PST US
Ira N224XS
echristley(at)nc.rr.com Guest
Posted: Thu Apr 17, 2008 6:48 pm Post subject: Questions on avionics |
bakerocb(at)cox.net wrote:
4/17/2008
Hello Ira,
aircraft."**
referenced to
person may ..." seen above would not apply to a person flying an
amateur built experimental aircraft.
I don't understand why you think what he said is wrong.
equipment ...Unless.... that equipment was tested and calibrated...;
or...that equipment meet the standards of TSO-C10b and TSO-C88
There's an OR statement there. One, the other, or both can be true, and
the statement is still true (I'm a Software Engineer by training, so I
took a special class just for that sort of reasoning 8*)
http://www.ronpaultimeline.com
mlas(at)cox.net Guest
Posted: Thu Apr 17, 2008 7:28 pm Post subject: Questions on avionics |
I would argue that you are not looking for a deviation to the TSO you
are looking to comply with the standard of the TSO without a formal
proof.
Mike
Posted: Thu Apr 17, 2008 7:34 pm Post subject: Questions on avionics |
Read the regulation. It says that the 'encoder' must meet the TSO
standards. It doesn't say that it must be TSO'd. That is a subtle
legal difference.
Mike
khorton01(at)rogers.com Guest
Posted: Fri Apr 18, 2008 2:30 am Post subject: Questions on avionics |
On 17 Apr 2008, at 23:29, Mike wrote:
legal difference.
But, if you read the TSO standards you would likely conclude that it
would be a very expensive and difficult job to do the testing to
determine whether the item met those standards. If the item must
meet all the TSO standards, it would almost certainly be more
practical simply to purchase a TSO'd item.
In the specific case of altimeters and altimeter encoders, the regs
provide an alternative - as others have noted you can comply with (b)
OR (c).
Kevin Horton
RV-8 (FInal Assembly)
Ottawa, Canada
http://www.kilohotel.com/rv8
rampil
Posted: Fri Apr 18, 2008 2:41 am Post subject: Re: Questions on avionics |
And of course, I was referring to encoding altimeters when I said there
was no requirement for TSO. Transponders must be TSO
nuckolls.bob(at)cox.net Guest
Posted: Fri Apr 18, 2008 5:32 am Post subject: Questions on avionics |
At 06:26 AM 4/18/2008 -0400, you wrote:
>legal difference.
You got that right. The actual testing is the cheap part.
I used to qualify products intended for use on TC aircraft
based on oversight of a single FAA representative for the
engineering testing in my lab. Nowadays, you first have to
get permission to test, then write up a test plan that speaks
to what color the walls of the lab will be painted, then schedule
a bevy of official dispensers of holy-water and witnesses
for testing (most of whom don't have a clue about how your
product works) and the accomplish this all in a laboratory that
is "certified" down to whether or not the paint cited in
the test plan has lead in it. Finally you have to write a test
report. Documents that support various phases of the test
effort must be submitted to the local ACO who is not just
allowed but EXPECTED to take 91 days to pray over it before
granting a blessing. If they do any red-lining, then they'll
take another 91 days to reconsider the changes. In the
mean time, the project team is still banging the project
work-order.
The value-added activity for proving that a product
meets its cited design goals is dwarfed by the no-value-added
activities foisted upon us those-who-know-more-about-airplanes-
than-we-do. If anyone really believes that last week's
air transportation debacle had anything to do with real
passenger safety is sadly deluded. It has everything to
do with lawmakers and regulators activities that
expand kingdoms over which they reign thereby justifying
their fat retirement packages.
The saddest part is that my contemporaries in the TC
aircraft world are so distracted by requirements to dance
to somebody else's orchestra that they're not building their
ability to be good engineers. That's what I'm getting paid
those big bucks for now . . . but I'm always watching for
some bright young bucks to whom I might pass the torch.
I think I've found a couple of new hires at HB that
show great promise. I've already conspired with their
boss to shield them as much as possible from the forces
that would dilute their curiosity, creative juices and
enthusiasm for their jobs.
In the mean time, you who are members of the 'unwashed'
must suffer the effects of all this pomp-and-circumstance
and be content with the dream that "their hearts are in
the right place . . . they're only concerned about your
safety." But if you had a non-TSO'd encoder that lacked
your confidence as to suitability to task, we could probably
assuage those concerns in one day of playing around in
the lab. To get real TSO blessings on the product would
require a 6-12 month, 400+ man-hour effort.
bakerocb
Posted: Sat Apr 19, 2008 4:15 am Post subject: Questions on avionics |
4/19/2008
Hello Ira, You wrote: "........I was referring to encoding altimeters when I
said there
was no requirement for TSO."
If that encoding altimeter is the altitude encoder that is feeding the
transponder required by FAR Sec 91.215 then it must comply with either
91.217 (b) or (c). That is what this thread has been about.
See my response to Mike, copied below, for more information.
'OC'
4/18/2008
Hello Mike, Thanks for your three emails. You wrote:
1) "....you are looking to comply with the standard of the TSO without a
formal
proof."
A) I invite you to look at "Subpart O -- TSO Authorizations" of FAR Part 21.
You can access it here:
http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?c=ecfr&sid=9dad7a792e03c09e14fc110ded0921cb&rgn=div6&view=text&node=14:1.0.1.3.9.15&idno=14
B) Then I invite you to look at TSO-C10b. You can access it here:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgTSO.nsf/0/072c91c58fdc6ce686256da4005f4d1b/$FILE/C10b.pdf
C) Then I invite you to look at TSO-C88b. You can access it here:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgTSO.nsf/0/625ebf9767dac15e8625727c006e10df/$FILE/TSO-C88b.pdf
D) Now I invite you (and here is the gotcha) to procure and look at all the
technical references contained in those TSO's. The TSO's themselves are just
sort of shell documents, pointers if you will. All the real technical guts
and standards that must be complied with are found in the references.
E) Now I ask you to picture the average homebuilder satisfying someone that
he is complying with the standards of the relevant TSO's without formal
proof.
2) "It says that the 'encoder' must meet the TSO standards. It doesn't say
that it must be TSO'd. That is a subtle legal difference."
I accept your "subtle legal difference". After you have gone through steps A
through D above I ask you to picture the average homebuilder satisfying
someone that his non TSO'd altitude encoder is meeting the standards of the
relevant TSO's .
3) "So answer me this: If you the builder /manufacturer determines that
your testing puts the encoder in compliances with the TSO standards......."
Again I ask you to picture the average amateur builder determining that his
testing puts the encoder in compliance with the TSO standards -- not some of
the standards, not just the performance standards, but the all of the TSO
standards. The reason that the EFIS manufacturers have not done this very
thing is because of the significant cost and bureacratic burden involved.
4) "...and you test the unit IAW 43.13 and it passes ......"
A) (I am not sure why you referenced 43.13. It does not appear to be
relevant here. Perhaps you meant FAR Sec 91.413. I will assume so.)
First off I, the amateur builder, am not permitted to perform the tests
required by 91.413 -- see sub paragraph (c) of 91.413.
B) "......what would be the ramifications?"
Second, assuming the tests required by 91.413 were properly performed by a
willing qualified person / entity, the automatic pressure altitude reporting
equipment containing the non TSO'd altitude encoder passed the tests, and
the test results were properly documented there probably would be no adverse
ramifications. But consider this:
B-1) Suppose a willing qualified person / entity is not readily available to
perform the 91.413 required tests because the non TSO'd altitude encoder is
not in compliance with 91.217? What are the ramifications then? Probably no
big deal, go find someone or some place that will perform the tests.
B-2) Suppose that there is a mid air collision between an amateur built
experimental aircraft and an airline aircraft with major loss of life. And
further suppose that the equipment in the amateur built experimental
aircraft had absolutely nothing to do with causing the accident, but the
media learns that the amateur built experimenal aircraft was not in
compliance with some Federal Aviation Regulation (91.217) . What are the
ramifications then?
5) "I don't see a violation of the rule as written."
I am not sure which rule you are referring to. If you are referring to
91.217 there are two choices:
A) Comply with subparagraph (c); ie have equipment that is TSO'd, or
B) Comply with the tests described in subparagraph (b). I think that the
tests required by 91.411 and 91.413 should be considered to meet the
requirements of 91.217 (b). Unfortunately, to date the FAA HQ does not agree
with me and they seem to have a little more authority than I do.
6) "Also their is no enforcement mechanism in place to even determine
whether your in compliance or not."
True enough. I think the FAA is too busy measuring the spacing between
lacings on wire bundles in the wheel wells of airliners to make very many
ramp checks on the avionics installed in amateur built experimental
aircraft, but see the ramifications comments above and make an informed
decision.
7) "You as the aircraft certifying authority as the builder......"
The Special Airworthiness Certificate in the Experimental Category for the
purpose of Operating Amateur Built Aircraft is signed and issued by an FAA
Representative who has been delegated that authority by the FAA
Administrator. The FAA Administrator is the certifying authority, not the
amateur builder.
"You ........ as the builder determine suitability as it pertains to the
regulations and no one else"
Try telling that to the FAA employee or DAR who comes to inspect your
amateur built experimental aircraft for its initial airworthiness
inspection. He will set you straight very quickly on who will make the
decisions regarding the suitability of your aircraft as it pertains to
regulations.
9) "Short of them scouring the wreckage for TSO tags they would have to make
an assumption."
I hope that it would never come to that, but the tenacity, search for
details, and the ill will of lawyers and journalists when they smell blood
and money should not be ignored. All I am seeking to do is to have people
make informed decisions -- I provide the information, they make the
decisions.
Time: 08:28:34 PM PST US
Subject: RE: AeroElectric-List: Questions on avionics
proof.
Mike
Time: 08:34:11 PM PST US
legal difference.
Mike
rampil
Posted: Sat Apr 19, 2008 5:57 am Post subject: Re: Questions on avionics |
Again, back to 91.217 (b):
This is just the performance test. It says nothing about TSO.
Part 21 and 23 do not apply to owner built aircraft with special
airworthiness certificates
klehman(at)albedo.net Guest
Posted: Sat Apr 19, 2008 6:03 am Post subject: Questions on avionics |
This is not totally theoretical. I am aware of a recent airliner that
took (mandatory) evasive action (and altitude bust) based on erroneous
transponder reporting from a unreported low altitude VFR airplane with
an unknown N number. Such TCAS inspired altitude busts are rare (but not
rare enough) and are usually chalked up to temporary glitches, but you
can see the risk involved. A TCAS RA warning takes precedence over ATC
assigned altitude. It is rare to positively identify the exact cause of
these events but apparently some transponders operate for awhile with
issues before they are discovered. I'd prefer an uncertified encoding
altimeter to a Tso'd blind encoder UNLESS there is any kind of legal
challenge. For the time being I use a Tso'd blind encoder but since I do
not often fly in controlled airspace with ATC altitude feedback, I
occasionally check my transmitted altitude with a PCAS MRX traffic
warning device. I suspect that such issues are one small part of the
drive towards encoding permanent aircraft idents into the newer
transponders.
Ken
| Quote: | B-2) Suppose that there is a mid air collision between an amateur built
ramifications then?
bakerocb
Posted: Sun Apr 20, 2008 4:55 am Post subject: Questions on avionics |
4/20/2008
1) "This is just the performance test."
I assume that you mean the testing required every two years by FAR Sec's
91.411 and 91.413 as appropriate.
I apologize for not having made the situation clearer to you. I also wanted
the testing required by 91.411 / 91.413 to sufficiently meet the
requirements of 91.217 (b) so that one could operate with an EFIS that
contained the only atitude encoder in the airplane and that altitude encoder
would be non TSO'd. So I wrote to FAA HQ asking that question. Here is an
exact quote of their response:
"Your letter posed the following questions:
1. If an amateur built experimental aircraft has an installed TSO'd ATC
transponder as required by Title 14 Code of Federal Regulations (14 CFR)
section 91.215, but a non-TSO'd altitude encoder and the installation has
passed the test and inspection requirements of 14 CFR sections 91.411 and
91.413 within the preceding 24 calendar months, does the installation meet
the requirements of 14 CFR section 91.217(b), and therefore make that
installation acceptable for IFR operations?
2. If the answer to question one is No, can you please tell me
why?
The answer to question one is "No." The testing required to show the
transmitted altitude data corresponds within 125 feet (on a 95 percent
probability basis) is more rigorous than the requirements referenced in 14
CFR sections 91.411, 91.413, and 14 CFR, part 43 appendices E and F. The
tests required by 14 CFR part 43 appendix E(c) measure the automatic
pressure altitude at a sufficient number of test points to ensure the
altitude reporting equipment performs its intended function.
Title 14 CFR section 91.217 paragraphs (b) and (c), state that pressure
altitude reporting equipment must be tested and calibrated to transmit
altitude data correspondence within stated specifications; or, the
altimeters and digitizers must meet the standards in TSO-C10B and TSO-C88,
respectively.
Should the owner/operator elect to exhibit compliance with tests and
calibration provided in 14 CFR section 91.217(b), a test method would need
to be developed that ensures the transmitted data corresponds within 125
feet of the indicated altitudes from sea level to the maximum operating
on a 95 percent probability basis. This testing also needs to ensure the
performance characteristics of the equipment are not impacted when
subjected to environmental conditions (voltage fluctuations temperature,
vibration, etc.) which may be encountered in airborne operations.
Completed tests and calibration results should be maintained in the
aircraft records.
Thank you for your interest in aviation safety."
So you can see that FAA HQ does not agree with our wishes. Further you can
see that an amateur builder attempting to comply with the FAA HQ version of
the testing requirements of 91.217 (b) in order to avoid having a TSO'd
altitude encoder installed in his airplane would have a very difficult /
impossible time doing so.
2) "It says nothing about TSO."
That is correct. The TSO part is found in 91.217 (c). So the person
mentioned in the beginning of 91.217 is given two choices -- he can comply
with either 91.217 (b) or (c).
3) "Part 21 and 23 do not apply to owner built aircraft with special
airworthiness certificates."
Basically true, but not specifically relevant to this discussion unless the
builder would try to use a non TSO'd altitude encoder by requesting approval
to deviate from TSO C-88b and its references in accordance with the
procedures of FAR Sec 21.609 -- not a trivial task.
Please let me know if I have not adequately described the situation.
Time: 07:01:52 AM PST US
Subject: AeroElectric-List: Re: Questions on avionics
Ira N224XS
