MWP
Joined: 25 Nov 2007 Posts: 1 Location: Centennial,Colorado
Posted: Sun Apr 13, 2008 7:40 am Post subject: Vixen Kit For Sale |
For <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />Sale Kitfox Vixen Kit
This is a partially complete Series 5, tri-gear, purchased in early 1995 with a few factory upgrades/options included such as a fully powdered coated (light blue) fuselage, tail structure and wing struts which is essentially all the steel parts of the airframe, dual adjustable rudder pedals, dual brakes and upper/lower false wing ribs. The original cost was just under $15K and since then I have added a few things such as a second fuel tank (now has a total of 26 gal), a strengthened nose wheel strut as a result of a service bulletin, stainless steel firewall, custom throttle quadrant (this is related to a dual carb engine), low fuel sensor system, dual Facet fuel pumps and associated wing tank plumbing and filters, a used fiberglass engine cowling, sound proofing material and some miscellaneous hardware. I have kept a log of my build activities along with a number of photographs detailing the construction. The kit has been assembled according to the factory supplied instructions and with the exception of installing the necessary wiring for instruments, lights, strobes etc. is generally ready for fabric covering. All the necessary Poly Fiber covering fabric is part of the kit along with Poly-Tak cement, Poly-Brush and Poly Spray coatings, however, these are now over ten years old and while there is no shelf-life specified, a sample covering job should be done to confirm their continued viability. I also have new in the box an ICOM IC-A200 radio and an Ameri-King AK_450 ELT.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
If any one is interested please contact me via e-mail at mkmbt(at)comcast.net (mkmbt(at)comcast.net) or via phone at 303-770-1953. This kit is located in the Denver, Colorado area.
Michael Pfeifer
_________________ Michael
303-770-1953 |
