flywrights(at)yahoo.com Guest
Posted: Sat Mar 29, 2008 7:50 pm Post subject: subpanel pics |
Trying to get ideas on how the rear on my panel/subpanel area should or could look. Please share any pics you may have so that I can get my brain in gear on what it will eventually look like back there!
Rob Wright
#392
Canopy with smoothprime and Doors !
">No Cost - Get a month of Blockbuster Total Access now. Sweet deal for Yahoo! users and friends. [quote][b]
Posted: Sun Mar 30, 2008 5:16 am Post subject: subpanel pics |
Rob,
Your panel layout will be the first starting point for the subpanel layout. What do you have in your panel and how it is organized? Contact me off-list and I would be happy to dialog a little bit on this.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 29, 2008, at 10:47 PM, Robert Wright wrote: | Quote: | Trying to get ideas on how the rear on my panel/subpanel area should or could look. Please share any pics you may have so that I can get my brain in gear on what it will eventually look like back there!
Rob Wright
#392
">No Cost - Get a month of Blockbuster Total Access now. Sweet deal for Yahoo! users and friends. | Quote: | http://www.matronics.com/Navigator?RV10-List
rene(at)felker.com Guest
Posted: Sun Mar 30, 2008 6:08 am Post subject: subpanel pics |
Rob, here is how I did it….
First, Stein built my panel and he used his alternate, 3 section one. (picture attached)
I did not rivet the forward section onto the fuselage and thus was able to mount the panel in the forward section on the work bench. From there I decided what had to be cut out and where to place everything. It was easy to mark locations and do the cutouts and then test fit…..many times. I attached everything on the sub-panel with screws and nutplates so that it would be easier to install in the airplane. I also installed a shelf, using nut plates, between the sub-panel and the firewall to hold the AHRS and in the end I mounted on more item to the bottom (dimmers). I found it hard to fit everything in a convenient place and thus had to make another shelf type extension for the relays, terminal board and manifold pressure sender. In the end it is not to much of a maintenance nightmare, I had to test that theory twice so far. Test number three is coming up next week………..going to change some wiring in the GRT and 430.
Rene'
801-721-6080
435.1 KB |
258 Time(s) |
