Dennis Johnson
Posted: Wed Apr 09, 2008 5:18 am Post subject: Risky Jump Starts? |
Greetings,
Someone posted on the rec.aviation.piloting newsgroup a story about damage caused by jumpstarting the airplane with the alternator switch on. According to the story, the jump start was from an FBO tug capable of "much more juice" than the owner's pickup truck that he had successfully used in the past, and as soon as he turned the key, "every breaker in the plane tripped." Sensors for fuel quantity, oil temp, ammeter, and oil pressure strip "got fried and needed to be rebuilt."
I'm having trouble understanding how getting a jump start with the alternator switch turned on could cause this problem. Even if it were a 12 volt system and the FBO tug produced 24 volts, I don't see why it would trip the circuit breakers.
Any ideas?
Dennis Johnson
Legacy, now flying
mprather(at)spro.net Guest
Posted: Wed Apr 09, 2008 6:09 am Post subject: Risky Jump Starts? |
I'm with you.. I don't see how leaving the alternator turned off would
have helped.
OWT People love to dramatize events.
Hooking 24V to a 12V system can blow breakers on some circuits - like
lighting. And can damage some items. Doubling the V, doubles the I -
when a circuit isn't regulated to constant P (which is true for many
things).
Matt-
| Quote: | Greetings,
Any ideas?
Dennis Johnson
Legacy, now flying
nuckolls.bob(at)cox.net Guest
Posted: Wed Apr 09, 2008 7:10 am Post subject: Risky Jump Starts? |
At 06:14 AM 4/9/2008 -0700, you wrote:
| Quote: | Greetings,
24 volts of normal polarity would not trip all the breakers . . .
however 24 volts of REVERSED polarity might. Ground power carts
are typically capable of 1000 to 2000 amp currents. A set of
paralleled-series diodes in an alternator would attempt to hold
off voltage rise of a reversed polarity . . . but the forward
conduction drop on a highly stressed diode is 1 volt or more. So
in milliseconds, the bus voltage goes minus to the tune of 2 volts
or more . . . at MANY amps. The battery would also attempt to stand
of the event . . . but we don't know if the battery was even on
line for this scenario. But if the battery were dead, it wouldn't
be much help.
The alternator breaker or b-lead fuse would open first and
probably before the alternator was damaged. As soon as the
breaker opens, then the bus voltage goes WAAAaayyyy negative
and really sad things start to happen . . . which may well include
the opening of a few more breakers.
I've had line-folks put 24v of the RIGHT polarity to my
14v airplane and that was scary enough. I've addressed this
possibility in the designs for ground power jacks in your
OBAM aircraft project. I've always recommended (1) ov protection,
(2) reverse polarity protection and (3) giving the pilot
absolute control of when power is applied to the ship's
systems. See:
http://aeroelectric.com/articles/grndpwr.pdf
The outcome of this story would not have been altered by
leaving the alternator switch OFF. I used to contribute to
the discussions on Usenet groups but had to give up after
discovering that many folks who hang out there are not
interested in (or perhaps capable of) understanding
the simple-ideas behind the physics that controls behavior
of their electrical systems.
( -Thomas Paine 1776- )
Posted: Wed Apr 09, 2008 7:14 am Post subject: Risky Jump Starts? |
| Quote: | Greetings,
be much help.
(UPON FURTHER REFLECTION, THE SCENARIO DESCRIBED MAY NOT HAVE
INCLUDED REVERSED POLARITY . . . THIS IS AN EXCEEDINGLY RARE
EVENT THAT IS USUALLY LIMITED TO RECENTLY SERVICED BATTERY
CARTS THAT HAVE BEEN IMPROPERLY ASSEMBLED. THIS PROBABLY WAS
A SIMPLE OVER VOLTAGE EVENT SUPPORTED BY A 1000+ AMP CURRENT
SOURCE. YOU THINK AN OV EVENT FROM A 60A ALTERNATOR IS BAD,
TRY A 1000A GROUND POWER CART!)
systems. See:
