Fuel flow test
DanM
PostPosted: Tue Mar 25, 2008 10:19 am    Post subject: Fuel flow test Reply with quote
I'm going to try and do the initial start of my 2200a engine, Kitfox IV, in about two weeks, I think a fuel flow test is necessary prior to the start. Anybody out there have information or documents on this procedure?
thanks
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
Lynn Matteson
PostPosted: Tue Mar 25, 2008 11:35 am    Post subject: Fuel flow test Reply with quote
I attended a forum given by Jack Dueck at Oshkosh in Summer of '05. I
think he works for the EAA at Oshkosh. I got a handout describing the
method. Maybe there's something online through EAA. I'd give them a
shout/email and see. I also think that Jabiru has a method that they
use, at least I read that somewhere. I'd give Pete, Andy or Jim a call.
Basically what you're doing is seeing if the fuel system will flow
150% of what the engine will require in a gravity-flow, high-wing
plane. The handout that I have talks in terms of weight of the fuel,
and has a graph that converts horsepower to lbs of fuel per hour.
Lynn Matteson
Grass Lake, Michigan
flying w/480+ hrs/down for annual
On Mar 25, 2008, at 2:19 PM, DanM wrote:
<danm(at)gangnailtruss.com>
thanks
Dan Mc Intyre
Kitfox Model IV, Jab 2200
http://forums.matronics.com/viewtopic.php?p=172578#172578
Lynn
Kitfox IV-Jabiru 2200
N369LM
avidaerobat(at)yahoo.ca
PostPosted: Tue Mar 25, 2008 1:38 pm    Post subject: Fuel flow test Reply with quote
The Fuel flow test is detailed in Tony Bingelis' book Fire Wall Forward (Page 175). A simplified version is described in EAA Experimenter, 2003 May edition. It is probably also somewhere in FAA's Acceptable Methods --- AC43.13. Part of the documentation for registration includes self certification that you have carried out a fuel flow test.
Ed
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> JabiruEngine-List message posted by: Lynn Matteson
Lynn Matteson
Grass Lake, [quote][b]
PostPosted: Tue Mar 25, 2008 2:37 pm    Post subject: Fuel flow test Reply with quote
Here is the exact wording from the FAA's Amateur-Built Aircraft and Ultralight Flight testing handbook which you can download at:
http://www.faa.gov/library/manuals/aircraft/media/ac90-89a.pdf
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
e. Fuel Flow and Unusable Fuel Check: This
is a field test to ensure the aircraft engine will get
enough fuel to run properly, even if the aircraft is
in a steep climb or stall attitude.
(1) First, place the aircraft’s nose at an
angle 5 degrees above the highest anticipated climb
angle. The easiest and safest way to do this with
a conventional gear aircraft is to dig a hole and place
the aircraft’s tail in it. For a nose gear aircraft, build
a ramp to raise the nose gear to the proper angle.
(2) Make sure the aircraft is tied-down and
chocked. With minimum fuel in the tanks, disconnect
the fuel line to carburetor. The fuel flow with a gravity
flow system should be 150 percent of the fuel
consumption of the engine at full throttle. With a
fuel system that is pressurized, the fuel flow should
be at least 125 percent. When the fuel stops flowing,
the remaining fuel is the ‘‘unusable fuel’’ quantity.
(3) Since the fuel consumption of most
modern engines is approximately .55 pounds per
brake horsepower per hour for a 100 horsepower
engine, the test fuel flow should be 82.5 pounds (13.7
gallons) per hour for gravity feed, or 68.75 pounds
(11.5 gallons) per hour for a pressurized system. The
pounds per hour divided by 60 equals 1.4 pounds
and 1.15 pounds per minute fuel rate respectively.
NOTE: Formula for fuel flow rate gravity
feed is .55 x engine horsepower x 1.50 =
pounds of fuel per hour divided by 60 to
get pounds per minute, divided by 6 to get
gallons per minute. For a pressurized system,
substitute 1.25 for 1.50 to determine
fuel flow rate.
f. Changing Fuel Flow or Pressure: If the
aircraft’s fuel flow rate is less than planned, there
is a volume or pressure problem. An increase in the
fuel flow volume may necessitate installation of
larger fuel line fittings on the fuel tanks, fuel selector,
and carburetor in addition to larger internal diameter
fuel lines. To increase fuel pressure, install an electrically
driven or engine driven mechanical fuel
pump prior to the first flight.
Lynn Matteson
[quote] --> JabiruEngine-List message posted by: "DanM"
thanks
Dan Mc Intyre
ianwilson2
PostPosted: Wed Mar 26, 2008 1:59 am    Post subject: Re: Fuel flow test Reply with quote
Dan,
There is a PDF document on how to do this at this website. http://www.xairireland.com/ go to XAir - Hawk - Downloads and you'll find a fuel flow document for the 2200.
I'm currently building one of these with a 2200a on the front - but I haven't got as far as you yet.
Good luck.
Ian Wilson
ElleryWeld(at)aol.com
PostPosted: Wed Mar 26, 2008 3:47 am    Post subject: Fuel flow test Reply with quote
I just finished Building the X-Air H in February that's a nice little airplane I am impressed with it , it went together quick and it's a rugged Design compared to a lot of planes of the same construction design and I hope to be building a lot more of them and The 2200 Jabiru wow that is a nice piece of Machine work and it is so smooth running compared to the Rotax that's my first choice for an engine on my own plane now
Ellery in Maine
In a message dated 3/26/2008 5:02:58 A.M. Eastern Standard Time, ianwilson2(at)hotmail.com writes:
--> JabiruEngine-List message posted by: "ianwilson2" <ianwilson2(at)hotmail.com>
Dan,
Good luck.
Ian Wilson
http://forums.matronics.com/viewtopic.php?p=172726#172726
Create a Home Theater Like the Pros. Watch the video on AOL Home.
