Posted: Mon Mar 24, 2008 6:23 am Post subject: fuel tank |
Dana- I think I will get the tank before I decide what to do. the 10 gallon tank is mounted high, over the BRS. The BRS is fully enclosed, and fires out the side through the fabric. maybe I can access through the seat back, but I think there is a strut in the way.
FS/KXP
Windsor Locks, Ct.
WhiskeyVictor36(at)aol.co Guest
Posted: Mon Mar 24, 2008 4:37 pm Post subject: fuel tank |
Bill,
I have removed the fuel tank from my Original FireStar by first disconnecting the vertical control rod that operates the ailerons. With that out of the way, the tank can be maneuvered, with a little finagling, through that triangular space, into the cockpit area.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 3/24/2008 10:24:07 A.M. Eastern Daylight Time, williamtsullivan(at)att.net writes:
| Quote: | Dana- I think I will get the tank before I decide what to do. the 10 gallon tank is mounted high, over the BRS. The BRS is fully enclosed, and fires out the side through the fabric. maybe I can access through the seat back, but I think there is a strut in the way.
FS/KXP
Windsor Locks, Ct.
ist href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
://forums.matronics.com/">http://forums.matronics.com
f="http://www.matronics.com/contribution">http://www.matronics.com/contribution
[/b] |
Create a Home Theater Like the Pros. Watch the video on AOL Home.
Posted: Mon Mar 24, 2008 5:08 pm Post subject: fuel tank |
Bill Sullivan,
Ooops! I forgot that you have a 10 gallon tank. That might not fit through the space I talked about below.
BV
In a message dated 3/24/2008 8:38:23 P.M. Eastern Daylight Time, WhiskeyVictor36(at)aol.com writes:
| Quote: | Bill,
Bill Varnes
Audubon NJ
FS/KXP
Windsor Locks, Ct.
[/b] |
