sundaypilot
Posted: Sat Mar 22, 2008 8:05 pm Post subject: CNC drilled pilot holes |
Hi all! I am new to this list so this may be a dumb question that has already been answered many times:
I saw a comment on the ZODIAC web site (under pricing) that says:
NEW FOR 2007: The standard kit now includes many precision CNC pre-cut and pre-drilled skins and components.
I am wondering if anybody has an idea or feeling as to how much time this will save? Do CNC pre-drilled holes still have to be deburred?
Any comment welcome.
I will start my project with a rudder -workshop in Cloverdale/CA in May.
Sundaypilot
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Sat Mar 22, 2008 8:31 pm Post subject: Re: CNC drilled pilot holes |
What you'll get are pre-cut skins with the pilot holes and inspection holes, etc. already done. I guess now they even trim the wingtips and wing roots which can be a lengthy process (especially the tips.)
The more they do the more time you will save and the less likely you are to put a hole in the wrong place. That said, we have many fine builders on this list that are building from scratch with great results. You have to decide how much time you are willing to devote to the project.
I bought the standard kit (not the quick build) and appreciate having the pilot holes and etc. I know it saved me time and to me it was worth the extra cost over just buying the raw materials.
Pilot holes are sized for a #40 drill. What they do is help you line up your skins with the underlying support members which you will then drill into and cleco. You will then have to drill the holes out to size (#30 or #21), disassemble, deburr, prime, reassemble and rivet. No doubt there will be some trimming with snips and files.
Don't let anybody kid you... there is a lot of work to putting one of these together. That said, I think Zenith offers kits that are the equal of or superior of what is available.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
sundaypilot
Posted: Sat Mar 22, 2008 8:37 pm Post subject: Re: CNC drilled pilot holes |
Thanks Tim!
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sat Mar 22, 2008 9:05 pm Post subject: CNC drilled pilot holes |
1st of all, the CNC predrilled holes are pilot holes as you said in your
subject. I.e., they are 3/32" holes. they must be drilled out to #30 for A4
rivets or #20 for A5 rivets, and the finished holes must be deburred before
riveting.
Regarding the time saving, I've made just a few pieces from scratch, but
enough to appreciate how much time it saves me to have a kit made of
precut, pre-pilot drilled parts. Admittedly, I am a slow builder, even with
the Zenith parts. But, when I look at the effort that would have been
required for a kit without the predrilled holes it looks overwhelming. For
me, I'd guess that the predrilled pilot holes save me ~10-15% of the time
to assemble. A significant part of that time is saved because it is a lot
easier for me to drill a hole in the correct spot when I'm guided by a
pilot hole rather than an X on the metal. A more skilled workman would
probably be a lot faster with undrilled parts.
Terry
At 09:05 PM 3/22/2008 -0700, you wrote:
| Quote: | Hi all! I am new to this list so this may be a dumb question that has
Sundaypilot
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Sun Mar 23, 2008 3:07 am Post subject: CNC drilled pilot holes |
The CNC holes are just pilot holes. They are your "guide" as to where to drill. The only time it saves is the time you would have spent measuring and marking these holes is all. Yes, you do have to deburr the skins and components after you drill them. You will understand it all and how it works when you start in on your rudder kit. I'm sure you will have a lot more questions so feel free to jump in here anytime and ask. That's what we are all here for - to help each other and learn.
Hope you enjoy building your airplane and welcome to the group!
Larry H
sundaypilot <sundaypilot(at)cybermesa.com> wrote:
| Quote: | --> Zenith-List message posted by: "sundaypilot"
Sundaypilot
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
Jaybannist(at)cs.com Guest
Posted: Sun Mar 23, 2008 5:38 am Post subject: CNC drilled pilot holes |
"Sunday", whoever you are,
The predrilled pilot holes do save a lot of time, except in the case where they are mis-drilled. I imagine that with all the feedback ZAC has gotten on this subject, they have it down pretty good by now.
Pilot holes are just that. They are drilled to accept a 3/32" cleco. You will have to drill out each one to fit an A4 or A5 rivet, so after drilling, you will have to de-burr each one.
Jay in Dallas CH 601XL N2630J "Lil Bruiser"
"sundaypilot" <sundaypilot(at)cybermesa.com> wrote:
Sundaypilot
http://forums.matronics.com/viewtopic.php?p=171868#171868
JohnDRead(at)aol.com Guest
Posted: Sun Mar 23, 2008 7:35 pm Post subject: CNC drilled pilot holes |
The CNC holes are pilot holes so they have to be deburred only when they are opened up to the correct size. The time saved is considerable as one does not have to lay out the holes initially.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 3/22/2008 10:10:10 P.M. Mountain Daylight Time, sundaypilot(at)cybermesa.com writes:
| Quote: | --> Zenith-List message posted by: "sundaypilot" <sundaypilot(at)cybermesa.com>
Sundaypilot
Create a Home Theater Like the Pros. Watch the video on AOL Home.
sundaypilot
Posted: Sun Mar 23, 2008 7:53 pm Post subject: Re: CNC drilled pilot holes |
Thanks everybody for your replies!
There seems to be a lot of collective Zodiac knowledge/experience gathered here. I will come back every day now to see what's new.
And I haven't even started building yet ...
Thanks again everybody!
Thomas (Tom) Spickermann
Hernandez, New Mexico
Terry Phillips
Posted: Sun Mar 23, 2008 9:40 pm Post subject: CNC drilled pilot holes |
Tom
Glad to hear that there is going to be a 601 down in NNM. I retired out of
LANL in 2004 and moved to MT in 2005. I feel so lucky to have missed the
turmoil of the past few years. In fact, I got out just before Nanos'
shutdown. That was a great summer to be out of the lab.
Do you plan to fly out of Espanola or LAM? I've been to the Espanola
airport, but only for some RC stuff. I do hope to fly to LAM after I finish
my 601.
Good luck with yours.
Terry
ESA-EPE, retired
At 08:53 PM 3/23/2008 -0700, you wrote:
| Quote: | Thanks everybody for your replies!
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
Terry Phillips
Posted: Sun Mar 23, 2008 10:02 pm Post subject: CNC drilled pilot holes |
Whoops!
'Sorry, I had intended my previous note to be off the list.
Terry
do not archive!
At 11:25 PM 3/23/2008 -0600, you wrote:
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
