kuffel(at)cyberport.net Guest
Posted: Tue Mar 25, 2008 9:17 am Post subject: True vs Indicated Airspeeds |
It was noted:
<< airspeed indicators being off much of the time, but this is
easy to fix. Go up on a Calm day, and mount a handheld GPS >>
Even better, I have an Excel spreadsheet where you enter 4 GPS
ground tracks and speeds. Output is 4 true airspeeds and wind.
Only 3 inputs are required. But if you fly an approximate square
pattern instead then you get redundant data which gives you an
estimate of accuracy.
Besides graphs of true vs indicated airspeeds at various
altitudes, this method can show your *real* stall speeds.
Email me direct for a copy.
Tom Kuffel
Whitefish, MT
Building Original FireStar
