Posted: Mon Mar 24, 2008 9:17 pm Post subject: KX plans |
Roger- The drawing you posted looks exactly like the original wings on my plane. The replacement wing set has a rear mount that was mounted 90 degrees off from the drawing (the attaching bolt for the u-joint goes the other way from the drawing.) The mount on the new wing set is a massive lug compared to the original (pictured). Dimensions from front to rear were different by a couple of inches. Maybe my plane is a Firestar/KX. What year are those plans?
Bill Sullivan
FS/KX
Windsor Locks, Ct.
R. Hankins
Joined: 18 Jan 2006 Posts: 185 Location: Grants Pass, Oregon
Posted: Tue Mar 25, 2008 6:26 am Post subject: Re: KX plans |
Bill,
The date on the "KX only" wing panel drawing is 4-25-85. The "KXP only" sheet is dated "AUG 1990" Several other sheets are labeled as "KX and KXP" , but it is easy to see that this was added to the original drawings at a later date. The only difference in the plans between KX and KXP are the wings and ailerons. The instruction manual has a few supplemental drawings for the KXP regarding the 503 engine. Otherwise, all else is the same. I ordered my KXP kit in early 1992. I'd be happy to check the plans for anything else if you have questions.
Have a good one,
_________________ Roger in Oregon
1992 KXP 503 - N1782C |
