heated pitot to plastic tube connector
rv10builder(at)verizon.ne
PostPosted: Fri Mar 21, 2008 4:47 pm    Post subject: heated pitot to plastic tube connector Reply with quote
Looked at archives and see questions on this but not the specific adaptor I'll need for the heated pitot tube copper connector to the plastic tubing I plan to use (instead of the aluminum).
anyone know what I need to make this connection happen?
Thanks!
Pascal
AV8ORJWC
PostPosted: Fri Mar 21, 2008 6:05 pm    Post subject: heated pitot to plastic tube connector Reply with quote
Tygon F4040-A Fuel and Lubricant tubing comes to mind. We use it on the turbine engines near a fuel transfer point with extreme heat near the exhaust stacks. Heat resistance is important but so is compatibility with cleaning solvents and hydrocarbons. YMMV.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Friday, March 21, 2008 5:44 PM
Subject: heated pitot to plastic tube connector
Thanks!
Pascal
tyf4040a.pdf
 Filename:  tyf4040a.pdf
 Filesize:  143.63 KB
 Downloaded:  320 Time(s)
PostPosted: Fri Mar 21, 2008 8:45 pm    Post subject: heated pitot to plastic tube connector Reply with quote
thanks John, what connector/connection/adaptor would I use to connect the copper connector from the pitot tube to this tubing?
Thanks!
Pascal
johngoodman
PostPosted: Sat Mar 22, 2008 10:45 am    Post subject: Re: heated pitot to plastic tube connector Reply with quote
Pascal,
What brand of heated pitot is it? Unless it's something unusual I'd think the adapters from Safair1 would work fine. Once you're about 5 or 6 inches away from the pitot, heat shouldn't be an issue. Scroll down this web page:
http://www.safeair1.com/index.htm
John
toaster73(at)embarqmail.c
PostPosted: Sat Mar 22, 2008 5:07 pm    Post subject: heated pitot to plastic tube connector Reply with quote
Pascal
Here is a setup I copied for my salvaged cessna heated probe. I just have the total not the total and static as is shown. The nylon part I used was PN 266N04X04 from spruce.
http://bmnellis.com/images/Wings/Dcp01628.jpg
Chris Lucas
#40072
