JOE HOWSE
Joined: 10 Jan 2006 Posts: 140 Location: DUNCAN BC CANADA
Posted: Wed Mar 19, 2008 7:47 pm Post subject: 285 timing |
The Chinese engine manual shows the timing tool; it is a strip of thin metal marked in degrees (looks like a metal ruler) ,
you slide it in between the upper cowl and the vane ring,
Then fasten a pointer to the propeller and with # 4 at TDC, position the metal strip so that the "0" mark matches the pointer, then move the prop to the required advance using the mag markings described by Dennis.
Joe
_________________ J.C. HOWSE |
