Compass Question
andynfultz(at)bellsouth.n
PostPosted: Mon Mar 17, 2008 10:14 pm    Post subject: Compass Question Reply with quote
I have just acquired a PAI-700 vertical card compass from a friend. He
had no documentation with this unit. Do any of you possibly know what the
proper procedure is for calibrating this compass? I went to PAI's website
hoping to find the info there, but there is no tech info at all on the
website. Thanks
Andy F.
Sbennett3(at)aol.com
PostPosted: Tue Mar 18, 2008 6:16 am    Post subject: Compass Question Reply with quote
Andy, After you install the compass in your plane,Get a brass screwdriver Line it up on either a runway, or a compass row and swing it.  If you have a runway 2/20. And the compass reads 030. Swing the airplane around, face 200 and see if its still 10 deg off. split the difference between. You should also swing it for East/West. Hope this helps. Steve Bennett
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
avidfox
PostPosted: Tue Mar 18, 2008 6:46 am    Post subject: Compass Question Reply with quote
Try this:
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/99c827db9baac81b86256b4500596c4e/$FILE/Chapter%2012-13.pdf
SECTION 3. GROUND OPERATIONAL CHECKS FOR AVIONICS EQUIPMENT
(NON ELECTRICAL
[b]12-37. COMPASS SWING
Yes..., I know it refers to a " wet compss" type, but the procedure is sound.
In lieu of a "Master Compass", many airports have a "compass rose" on the "ramp" just for this purpose.
Steve Benesh A&P, IA
KF 5\ 912UL
[/b]
Float Flyr
PostPosted: Tue Mar 18, 2008 11:04 am    Post subject: Compass Question Reply with quote
Hi Andy
Check the archives for “compass swings” There should be a nice easy to follow set of instructions there.
Do not archive.
Noel Loveys
Campbellton, NL, Canada
CDN AME intern, PP-Rec
C-FINB, Kitfox III-A
582 B box, Ivo IFA, Aerocet 1100 floats
[url=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]
 Filesize:  7.29 KB
 Viewed:  3038 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Tue Mar 18, 2008 7:54 pm    Post subject: Compass Question Reply with quote
Thanks Steve. Sounds like the vertical card compas I have swings no differently than most others. That's what I was wondering. Thanks.
Andy
[quote] --
