rsteele(at)rjsit.com Guest
Posted: Mon Mar 17, 2008 3:04 pm Post subject: Aileron Hinges |
I think I want to used hinged ailerons on my XL. I'll be darned if I
can find anything about them in either the plans or assembly guide.
I thought they were a standard option. Can someone point me in the
right direction to this info?
Ron
Posted: Mon Mar 17, 2008 3:25 pm Post subject: Aileron Hinges |
They have their own page in the plans: 6-PH-1 ("Piano Hinged"). This is
shown on the cover page for the plans 6-X-0. The actual page is towards the
back of the plans with the other options and motor mounts.
-- Craig
scottbevier
Posted: Mon Mar 17, 2008 3:32 pm Post subject: Aileron Hinges |
They are shown on drawing 6-PH-1, dated Jan. 04
Scott Bevier
601XL from plans
psm(at)ATT.NET Guest
Posted: Mon Mar 17, 2008 5:47 pm Post subject: Aileron Hinges |
Hi Ron,
Sorry, hinged ailerons are an option on the XL. The standard way to
mount the ailerons is with skin aluminum. You can order the aileron
option from ZAC.
I personally think the hinge-less ailerons are a better choice than
the hinged ones. They make a perfect seal and work just fine. The
ailerons are a little stiff, but they don't require much movement to
get the roll you need.
Good luck,
Paul
XL fuselage
| Quote: | I think I want to used hinged ailerons on my XL. I'll be darned if I
Ron
