Rhonda(at)bpaengines.com Guest
Posted: Fri Mar 14, 2008 5:03 am Post subject: Fuel Injector Servo SB/Emergency AD |
You should also be aware that the Precision SB and Emergency AD apply not only to new certified RSA5 and RSA10 servos and the experimental Precision Silverhawk systems but also apply to any systems overhauled or repaired by in the field since August 1, 2006. So, even if you purchased an overhauled engine from a shop like mine, Lycon or countless others and it has a Bendix/Precision system on it, you need to comply with this AD for your own safety.
Rhonda Barrett-Bewley
Barrett Precision Engines, Inc.
2870-B N. Sheridan Rd.
Tulsa, OK 74115
(918) 835-1089 phone
(918) 835-1754 fax
www.barrettprecisionengines.com
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Dunne
Sent: Friday, March 14, 2008 1:07 AM
Subject: RE: Fuel Injector Servo SB
This is the FAA AD Ron is referring to in case some of you don’t have the info through the mail yet..
I could say something with regards experimental and some earlier comments but I’ll resist J
John 40315.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Friday, 14 March 2008 2:17 PM
Checked my injector servo at lunch time (straight out of the box, not yet installed). Although the plug was lockwired it was clearly loose. Since the only heat my engine has been exposed to is the test run conducted at the factory, shrinkage of the seal with heat is not the only problem here. I doubt the plug was properly torqued at the factory before delivery.
check those servos!!
cheers,
Ron | Quote: |
Sent: Friday, 14 March 2008 8:55 AM
Subject: Fuel Injector Servo SB
G'day all,
There is a service bulletin on the Precision Airmotive series of Fuel Injectors requiring immediate attention. http://www.precisionairmotive.com/Publications/PEX-1.pdf refers.
I have not checked the part number of the servo delivered with my new Lyco from Vans, but I'm pretty sure it is one of the affected items.
I don't recall seeing any posts on this issue on the list, so I thought I would pass on the details. Apologies in advance if this is not relevant to the fuel injection servos we have on our 540's.
Ron
-187 finishing (was going to install the servo tonight!) | Quote: | | "Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toThe information contained in this email and any attached files is | 0 | Quote: | | The information contained in this email and any attached files is | 1 | Quote: | | The information contained in this email and any attached files is | 2 | Quote: | | The information contained in this email and any attached files is | 3 | Quote: | | The information contained in this email and any attached files is | 4 | Quote: | | The information contained in this email and any attached files is | 5 | Quote: | | The information contained in this email and any attached files is | 6 | Quote: | | The information contained in this email and any attached files is | 7The information contained in this email and any attached files is | 8 | Quote: | | The information contained in this email and any attached files is | 9 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 0 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 1 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 2 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 3 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 4 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 5 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 6 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 7 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 8 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 9 | Quote: | | recipient, any use, disclosure or copying of this email or any | 0 | Quote: | | recipient, any use, disclosure or copying of this email or any | 1 | Quote: | | recipient, any use, disclosure or copying of this email or any | 2 | Quote: | | recipient, any use, disclosure or copying of this email or any | 3 | Quote: | | recipient, any use, disclosure or copying of this email or any | 4[/b]recipient, any use, disclosure or copying of this email or any[/quote]5 | Quote: | | recipient, any use, disclosure or copying of this email or any | 6--> http://forums.matronics.com[/b]recipient, any use, disclosure or copying of this email or any[/quote]7 | Quote: | | recipient, any use, disclosure or copying of this email or any | 8
Ray.R.Doerr(at)sprint.com Guest
Posted: Fri Mar 14, 2008 7:27 am Post subject: Fuel Injector Servo SB/Emergency AD |
As I understand it, if you had your before the August 1, 2006 date, it did not apply. Is this correct?
Thank You
Ray Doerr
CDNI Principal Engineer
Sprint PCS
16020 West 113th Street
Lenexa, KS 66219
Mailstop KSLNXK0101
(913) 859-1414 (Office)
(913) 226-0106 (Pcs)
(913) 859-1234 (Fax)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rhonda Bewley
Sent: Friday, March 14, 2008 8:04 AM
Subject: RE: Fuel Injector Servo SB/Emergency AD
Tulsa, OK 74115
(918) 835-1754 fax
John 40315.
cheers,
Ron | Quote: |
G'day all,
Ron
-187 finishing (was going to install the servo tonight!) | Quote: | | "Warning:The information contained in this email and any attached files isconfidential to BAE Systems Australia. If you are not the intendedrecipient, any use, disclosure or copying of this email or anyattachments is expressly prohibited. If you have received this emailin error, please notify us immediately. VIRUS: Every care has beentaken to ensure this email and its attachments are virus free,however, any loss or damage incurred in using this email is not thesender's responsibility. It is your responsibility to ensure viruschecks are completed before installing any data sent in this email toThe information contained in this email and any attached files is | 0 | Quote: | | The information contained in this email and any attached files is | 1 | Quote: | | The information contained in this email and any attached files is | 2 | Quote: | | The information contained in this email and any attached files is | 3 | Quote: | | The information contained in this email and any attached files is | 4 | Quote: | | The information contained in this email and any attached files is | 5 | Quote: | | The information contained in this email and any attached files is | 6 | Quote: | | The information contained in this email and any attached files is | 7The information contained in this email and any attached files is | 8 | Quote: | | The information contained in this email and any attached files is | 9 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 0 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 1 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 2 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 3 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 4 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 5 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 6 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 7 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 8 | Quote: | | confidential to BAE Systems Australia. If you are not the intended | 9 | Quote: | | recipient, any use, disclosure or copying of this email or any | 0 | Quote: | | recipient, any use, disclosure or copying of this email or any | 1 | Quote: | | recipient, any use, disclosure or copying of this email or any | 2 | Quote: | | recipient, any use, disclosure or copying of this email or any | 3 | Quote: | | recipient, any use, disclosure or copying of this email or any | 4[/b]recipient, any use, disclosure or copying of this email or any[/quote]5 | Quote: | | recipient, any use, disclosure or copying of this email or any | 6 | Quote: | | recipient, any use, disclosure or copying of this email or any | 7 | Quote: | | recipient, any use, disclosure or copying of this email or any | 8 | Quote: | | recipient, any use, disclosure or copying of this email or any | 9 | Quote: | | attachments is expressly prohibited. If you have received this email | 0 | Quote: | | attachments is expressly prohibited. If you have received this email | 1 | Quote: | | attachments is expressly prohibited. If you have received this email | 2 | Quote: | | attachments is expressly prohibited. If you have received this email | 3 | Quote: | | attachments is expressly prohibited. If you have received this email | 4 | Quote: | | attachments is expressly prohibited. If you have received this email | 5 | Quote: | | attachments is expressly prohibited. If you have received this email | 6 | Quote: | | attachments is expressly prohibited. If you have received this email | 7 | Quote: | | attachments is expressly prohibited. If you have received this email | 8 | Quote: | | attachments is expressly prohibited. If you have received this email | 9 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 0 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 1 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 2 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 3 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 4 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 5 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 6 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 7 | Quote: | | in error, please notify us immediately. VIRUS: Every care has been | 8
Posted: Fri Mar 14, 2008 7:35 am Post subject: Fuel Injector Servo SB/Emergency AD |
That’s how I read it.
[i]Rhonda[/i]
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R [NTK]
Sent: Friday, March 14, 2008 10:24 AM
Thank You
Ray Doerr
Sprint PCS
Lenexa, KS 66219
Mailstop KSLNXK0101
Tulsa, OK 74115
(918) 835-1754 fax
John 40315.
cheers,
Ron | Quote: |
G'day all,
Ron
