wlively(at)gvtc.com Guest
Posted: Sun Mar 09, 2008 12:38 pm Post subject: ANL/ANN current limiter |
Hello
I have a relatively long run (10+ ft) of 1/0 CCA main battery power wire in my -8 I am building from the rear baggage all the way to the front firewall. I would like to install an current limiter on the output of the battery as an added layer of protection for my long wire run. I know Mr. Nuckolls has not advocated that on small aircraft, but I want to do it anyway as peace of mind since the wire passes thru quite few bulkheads and want to have something which will trip alot faster than I can act. So, which is the better choice, ANN or ANL and what current rating would be best, I have a 200 hp angle valve to start?
Thank you,
Wade Lively
N100WL, reserved
nuckolls.bob(at)cox.net Guest
Posted: Mon Mar 10, 2008 7:44 am Post subject: ANL/ANN current limiter |
At 01:35 PM 3/9/2008 -0700, you wrote:
Hello
An ANL200 will carry 300A continuously. See:
http://www.aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
This device can practically be expected to carry
worst case cranking currents without nuisance tripping.
At the same time, if you did fault that cable to
the edge of a lightening hole, the same ANL will
probably not trip while the wire burns its way
clear at the edge of the hole.
This is why these circuits have not been "protected"
in TC aircraft. Protection robust enough to stay
connected for worst case cranking will also carry
more than enough current in a 'soft fault' condition
to burn away the offending aluminum with little or
no damage to the copper.
