Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Sun Aug 31, 2008 3:39 am Post subject: Hook up wire |
Trying to wire up my 601.
What gauge wire should I use on things like the fuel senders. I was considering using 20G. I will be using 18G for things like lights that draw a bit of power.
Thank you.
Ianrat
Posted: Sun Aug 31, 2008 5:17 am Post subject: Hook up wire |
Hello Ianrat,
The gage I used was predominantly 16G Tefzel for everything, with
exception to 22G for gages and panel lights.
Ianrat wrote:
Thank you.
Ianrat
http://forums.matronics.com/viewtopic.php?p 1769#201769
amyvega2005(at)earthlink. Guest
Posted: Sun Aug 31, 2008 5:39 am Post subject: Hook up wire |
you will get humming from the alternator so use shielded plugs , plug wires, and get a toriodal coil noise suppressor right to the back of the radio. The biggest is grounding. check all your grounds, My lights turned on caused voltage to course through the plane and I could hear it in the radio. once off the noise went off.
juan
juan
bryanmmartin
Posted: Sun Aug 31, 2008 1:16 pm Post subject: Hook up wire |
Heres an excel file you might find useful: http://www.rst-engr.com/rst/jimsdata/index.html
Click on "Wire Table".
A good rule of thumb is to size the wire for no more than a 3% (about
half a volt for a 14V system) voltage drop over the length of the wire
at the maximum current the circuit will see and use a fuse or circuit
breaker that will allow no more than about a 20C temperature rise at
its rated current.
Here's another chart that might be useful: http://home.hiwaay.net/~langford/wiresize.html
This data in this chart looks about right to me.
20 gauge wire will work fine for the fuel senders. 18 gauge will
probably work for the nav lights if the current is not much more than
5 amps. The 3% voltage drop rule isn't too critical for simple
lighting circuits.
Personally I would use 16 gauge for most of the lighting circuits and
power feeds and use the smaller stuff for wiring up signal lines in
the panel and audio circuits. Halogen type landing lights will require
at least a 12 gauge wire due to the long run and high current. Some of
your gauges might require a relatively large ground wire (16 gauge or
so) to minimize the voltage drop to ground for better accuracy.
I ran most of my ground wires to a common terminal block adjacent to
the point where the main battery ground was located. This helps to
reduce the chance of noise in the audio circuits.
On Aug 31, 2008, at 7:39 AM, Ianrat wrote:
Thank you.
Ianrat
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
