High temperature fiberglass
paul.the.aviator(at)gmail
PostPosted: Sat Mar 08, 2008 6:09 pm    Post subject: High temperature fiberglass Reply with quote
Hi all,
I was looking at a Rotax installation in a Diamond Kintana the other
day and I noticed that they have manufactured a fiberglass plenum air
duct to drive the airflow over the cylinder heads and downwards.
Anyhow, I am curious about what type of fiberglass cloth and resin
system they use that could withstand the temperatures under the
cowling. Does anyone have any idea ?
Thanks, Paul
kheindl(at)msn.com
PostPosted: Sat Mar 08, 2008 7:04 pm    Post subject: High temperature fiberglass Reply with quote
Paul,
I wouldn't know the answers to those questions. Most 912S's have that shroud. I once checked the temperature under the shroud and found it only to be about 45C above oat. I was hoping to tap into that for cabin heat, but it wasn't hot enough, at least not near the front of the engine. Of course the under cowling temperatures rise dramatically after engine shutdown.
Karl
<html><div></div></html>
Date: Sat, 8 Mar 2008 20:05:11 -0600
Subject: High temperature fiberglass
--> Europa-List message posted by: "Paul McAllister" <paul.the.aviator(at)gmail.com>
Hi all,
&gt======================
craigb(at)onthenet.com.au
PostPosted: Sat Mar 08, 2008 11:39 pm    Post subject: High temperature fiberglass Reply with quote
There are many high temp epoxy systems available which will
handle temps up to 450f, the use of carbon fibre cloth will help as well
but glass cloth should be more than adequate. I saw ONCE (do you think i can find it again) that there was an epoxy capable of being used to fabricate exhaust headers if used with carbon fibre cloth. Imagine the
weight saving. Rolling Eyes
If it is just ground temps after shut down you are concerned about, maybe
you could put a small 12v brush-less DC fan to move some air after shut down, they are small light and draw about half an amp. Only issue would be the mounting so it worked ok when stopped but didn't get destroyed in flight
Craig
Visit - www.EuropaOwners.org
ptag.dev(at)tiscali.co.uk
PostPosted: Sat Mar 08, 2008 11:46 pm    Post subject: High temperature fiberglass Reply with quote
Hi! Paul
No specific temperatures but due to a minor conflict with the vac pump I
used I had to apply heat to the plenum/hood and it responds to
temperature and allows a deformation so IMHO it is still standard resin
and fiberglass.
I am catching air aft of oil cooler and radiator with adequate heat (not
as hot as I used to get from the Jabiru oil Cooler but comfortable.
Bob Harrison.G-PTAG (914 with option of the hood by Rotax
pete(at)lawless.info
PostPosted: Sun Mar 09, 2008 12:23 am    Post subject: High temperature fiberglass Reply with quote
Karl do you mean 4.5 degrees C above OAT?
Gilles.Thesee(at)ac-greno
PostPosted: Sun Mar 09, 2008 12:46 am    Post subject: High temperature fiberglass Reply with quote
and fiberglass.
Bob and all,
This airshroud is not transparent, its opaque appearance reminds me of
the so-called "High temp" resin we used for some parts in the engine
compartment. Those part needed some heat treatment in an oven after cure
in order to avoid brittleness.
I too devised a cabin heat pickup in the rear of the radiator tunnel.
The radiators are in tandem, so we get plenty of heat, especially when
OAT is cold and the tunnel flap is closed.
Best regards,
Gilles
http://contrails.free.fr
ami(at)mcfadyean.freeserv
PostPosted: Sun Mar 09, 2008 2:35 am    Post subject: High temperature fiberglass Reply with quote
Aside from the exhausts, the hottest external part of a 912 is the cylinders (walls, not head), which are allowed a maximum temp of 190C.
There are a number of high temp epoxies available. Cheap and widely obtainable is the Borden Chemical range, which has a Tg of 150C (following post cure).
I suspect that the epoxy in the Rotax hood is loaded with fire retardant (probably Antimony Trioxide), hence its opaque white colour. I've not otherwise found a high temp resin that is fire retardant, or a fire retardant epoxy (there are lots in use for marine applications, to keep the insurance companies happy) that has other than a low Tg. Still doesn't explain the extraordinary high cost of the Rotax cylinder hood.
Duncan McF.
Hi all,
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
kheindl(at)msn.com
PostPosted: Sun Mar 09, 2008 3:37 am    Post subject: High temperature fiberglass Reply with quote
No, forty-five.
[quote] From: pete(at)lawless.info
Subject: RE: Europa-List: High temperature fiberglass
Date: Sun, 9 Mar 2008 08:18:34 +0000
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass h1 {margin-right:0cm;margin-bottom:0cm;margin-left:326.05pt;margin-bottom:.0001pt;page-break-after:avoid;font-size:12.0pt;font-family:'Times New Roman';font-weight:bold;} .ExternalClass h2 {margin-bottom:.0001pt;page-break-after:avoid;font-size:12.0pt;font-family:'Times New Roman';font-weight:normal;} .ExternalClass h3 {margin-bottom:.0001pt;text-align:center;page-break-after:avoid;font-size:12.0pt;font-family:'Times New Roman';font-weight:bold;} .ExternalClass EC_p.MsoEnvelopeAddress, .ExternalClass EC_li.MsoEnvelopeAddress, .ExternalClass EC_div.MsoEnvelopeAddress {margin-right:0cm;margin-bottom:0cm;margin-left:144.0pt;margin-bottom:.0001pt;font-size:12.0pt;font-family:Arial;} .ExternalClass EC_p.MsoEnvelopeReturn, .ExternalClass EC_li.MsoEnvelopeReturn, .ExternalClass EC_div.MsoEnvelopeReturn {margin-bottom:.0001pt;font-size:12.0pt;font-family:Arial;} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_p.NormalWeb1, .ExternalClass EC_li.NormalWeb1, .ExternalClass EC_div.NormalWeb1 {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass EC_span.EmailStyle22 {font-family:Arial;color:navy;} (at)page Section1 {size:595.3pt 841.9pt;} .ExternalClass EC_div.Section1 {page:Section1;}
kheindl(at)msn.com
PostPosted: Sun Mar 09, 2008 3:43 am    Post subject: High temperature fiberglass Reply with quote
I recall seeing a note by Bob Berube, saying that he throws away these shrouds, claiming that they are useless. I am not sure
I agree, so long as the air is directed into it, as with the Europa FWF kit
hdwysong(at)gmail.com
PostPosted: Sun Mar 09, 2008 9:59 am    Post subject: High temperature fiberglass Reply with quote
Hello Paul,
Standard E-glass BID and EZ Poxy have been successfully used to build
cooling plenums for pushers/canards (Long EZ, Varieze, etc.). Google
"downdraft cooling eze" for some details. You'll need to post cure
the plenums in order to elevate the temps at which the resin goes
"soft", so any resin system that benefits from a post cure should
suffice.
Folks have also impregnated 2 or 3 plies of BID cloth directly with
RTV to make their plenums. Sounds strange and messy, but it works.
Put down a piece of plastic drop cloth, add 1 ply of BID (cut to
shape), squirt on some RTV, add another piece of drop cloth, and use a
rolling pin to squish the RTV through the BID. Build it up to 3 plies
and, before it cures, pull off one side of drop cloth and stick the
exposed RTV directly onto your cylinder fins and mold the 3-ply sheet
to shape.
D
jeff(at)rmmm.net
PostPosted: Sun Mar 09, 2008 1:41 pm    Post subject: High temperature fiberglass Reply with quote
Hello All,
I too have been contemplating making these plenums as I'm still
struggling with keeping the back cylinder temps down. Today with some
engine static test I had the back # 3 cylinder temp at 260 to 265 F.
Not a problem at the current 60 F outside but I know the hot Florida
temps at Sun-N-Fun could again push the limit for me. Last year during
climb out there, and during our Tennessee heat wave they were a
problem. Lower climbs we're necessary. After many attempts trying every
suggestion talked about on this forum and elsewhere. My back CHT's are
still too high and when it's cold they are too un even from the fronts
as well.
My friend Steve Wright of the Stagger EZ fame told me that a plenum
would be the only way to get the heads running at an even and at cooler
temperatures. He made his with the RTV mentioned below. Unless I have
any other suggestions it looks like the plenum may be the way to go.
Can these be bought or is there anyone out there that has discarded
there's. If not I'll be making some as well.
Your thought are very welcome here.
Jeff R.
A258 - N128LJ / Gold Rush 105 hours and climbing slowly.
Hello Paul,
suffice.
to shape.
D
PostPosted: Sun Mar 09, 2008 2:09 pm    Post subject: High temperature fiberglass Reply with quote
Hi all,
Well I got an overwhelming response to my question about high
temperature resins and cloth, so perhaps I need to come clean as to
what I am thinking about.
As some of you know I purchased a second 914 minus its exhaust and
turbo charger and as a winter time project I have been rebuilding it
with the thought to fuel inject it.
Well I am at the point where I am about to assemble the engine and I
am thinking about how I was going to make an inlet manifold from the
throttle body. My initial thought was to fabricate one out of
aluminum like the one in the attached photograph.I then got to
thinking that perhaps I can make something that has a nicer airflow
out of blue foam and fiberglass.
As far as the project goes, it is very much a spare time project with
no particular time line. It is truly experimentation and my never
actually get fitted to my aircraft.
So, essentially I am looking for a recommendation of an epoxy resin
that will be okay with the temperatures seen under the cowl.
Cheers, Paul
 Filesize:  142.87 KB
 Viewed:  200 Time(s)
PostPosted: Sun Mar 09, 2008 2:25 pm    Post subject: High temperature fiberglass Reply with quote
Hi! Jeff/all
These items are called "Barrel hoods" and are available as a Rotax
Option in the region of GBP £200.!
No doubt the plug around which to make these was a very demanding
process and requires a tight dimensional tolerance.
However with the benefit of one it would be easy to make a "splash" and
copy it.
Bob Harrison. G-PTAG
PostPosted: Mon Mar 10, 2008 3:47 pm    Post subject: High temperature fiberglass Reply with quote
Can't think who would do such a dastardly thing, robbing Rotax of income!
D.
