mgoodrich(at)tampabay.rr. Guest
Posted: Tue Feb 28, 2006 8:21 pm Post subject: Back-Up Battery |
Hello All,
I am installing a back-up battery an would like to monitor
the condition (voltage) w/warning for it. Any ideas on
what to use???
Mitchell Goodrich
VEZE Tampa
Bill Schlatterer
Posted: Tue Feb 28, 2006 9:17 pm Post subject: Back-Up Battery |
If using the Grand Rapids EFIS system, it monitors voltage on each of up to
three separate power sources. Other EFIS systems probably handle several as
well.
Bill S
7a wiring
nuckollsr(at)cox.net Guest
Posted: Wed Mar 01, 2006 6:35 am Post subject: Back-Up Battery |
At 11:19 PM 2/28/2006 -0500, you wrote:
Quote: |
<mgoodrich(at)tampabay.rr.com>
Hello All,
what to use???
It would help us to know how you intend to install
it. Like figure Z-30? There's a product about to be
added to our bag of tricks. You can see the data
package at:
http://www.aeroelectric.com/Catalog/AEC/9011/9011-700-1C.pdf
It's a two channel low voltage, single channel latching
high voltage management module. Designed specifically
for generator installations on older airplanes, it's
still applicable to a variety of modern applications.
One might consider this device for any or all of its
functional features. It will cost about the same
as the current LVWarn/ABMM module . .
http://www.aeroelectric.com/Catalog/AEC/9005/9005-701B.pdf
but with 3x the functionality. So if you need only
one channel of LV warning (to watch your aux battery
circuit), you could certainly consider it. If you also
found uses for the remaining features, that's icing
on the cake.
Alternatively, you could craft your own LV warning
module by taking advantage of the ready-to-stuff
etched circuit board and fabrication package
offered at:
http://aeroelectric.com/articles/lvwarn/LVWarn-ABMM.html
and . .
http://aeroelectric.com/articles/lvwarn/9021-620.pdf
