naumuk(at)alltel.net Guest
Posted: Sat Feb 23, 2008 1:05 pm Post subject: Saddle, pt II |
All-
On lister advice, decided to wait until rear top skins were in place before fitting the saddle. Rough rigged elevator; will have to pore over ACS catalog to get electrical fittings to connect tail light, elevator trim, and belly strobe. Will also have to install a fitting attached to the lower fuse to support cables. Then I can install the rear fuse top skins.
Note: HF cable cutting pliers are a POS. The ACS $15.00 Nico Press squeezer is barely adequate for the assembly of 1 project. I have 2 fittings to go and the squeezer is about shot.
90% done, 95% to go!
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
dredmoody(at)cox.net Guest
Posted: Sat Feb 23, 2008 2:21 pm Post subject: Saddle, pt II |
For the five conductor trim cable, go to Radio Shack and buy the panel mount plug for a CB mic. It has five pins and has a locking ring to keep it securely plugged.
Dred
Posted: Sat Feb 23, 2008 8:48 pm Post subject: Saddle, pt II |
Dred-
Sounds good. Any pictures? Wondering about the male connector.
Posted: Sun Feb 24, 2008 7:37 am Post subject: Saddle, pt II |
The plane just moved to the new hangar yesterday. I had run out of room to continue in my backyard shop. I do not have a decent photo of the connector. Go to www.radioshack.com and search 4-pin panel mount microphone audio jack. Then search 4-Pin Female CB and HAM Radio Microphone Plug 4-Pin Female CB and HAM Radio Microphone Plug . Those two searches will show you the two connectors in a 4-pin model. I know for a fact (I have three sets of them) that Radio Shack has a 5-pin version as well. There are other ways to skin this cat but this connector is one good way.
Dred
