bbreckenridge(at)gmail.co Guest
Posted: Tue Feb 28, 2006 9:28 am Post subject: I have a Friend who screwed up his rudder - what would you |
"Worse yet, the rivets are -4, not -3. In other words, the holes are already drilled out with a #30 bit."
I haven't crossed this bridge yet, but what about the OOPS rivets? Countersunk head, #30 shaft, a possibility? Maybe the drilled out hole would be too big, but it might be worth trying it on one rivet to see how it looks. My one question: are the countersinks for #30 as well?
Bruce
40018
elevators
jdalton77(at)comcast.net Guest
Posted: Tue Feb 28, 2006 10:13 am Post subject: I have a Friend who screwed up his rudder - what would you |
I have some oops rivets. I'm just nervous about drilling out the -4's and making the hole too big.
gommone7(at)bellsouth.net Guest
Posted: Tue Feb 28, 2006 10:46 am Post subject: I have a Friend who screwed up his rudder - what would you |
| Quote: | If I'm you I will leave as it is,you will have plenty of time to re do the rudder,any way you can't go 200 mph in the testing time,after is all done and you flying ,order another one and build it.thats probably one of the low cost parts in the plane,and the easiest to replace.
My opinion
Hugo
| Quote: | From: "bruce breckenridge" <bbreckenridge(at)gmail.com>
ron.mcgann(at)baesystems. Guest
Posted: Tue Feb 28, 2006 3:41 pm Post subject: I have a Friend who screwed up his rudder - what would you |
Tip du jour:
Avery have a Universal Head rivet removal tool (Part # 40053). I received mine a few weeks ago and have used it to remove only a handful of rivets so far. Although fairly pricey (at) $75, I reckon it's invaluable. Builders starting out will find setting 1/8" universal head rivets hard enough, removing them without enlarging or totally destroying the hole can be even harder. This tool perfectly centres the drill bit and sets the correct drill depth, the head snaps off easily, and with a little backing support the rivet shank drives out with a punch. The result is a hole that is as good as the original, enlarged only by the expansion of the rivet when first set.
If you have a large number of universal head rivets to remove, like perhaps on your trailing edge, or frequently remove dud uni head rivets, this tool is a godsend.
cheers,
Ron
[quote] --
