		Dana
				 Posted: Wed Feb 20, 2008 6:35 pm    Post subject: Tires, was: Re: Building your own gear legs |
				At 08:41 PM 2/20/2008, John Bickham wrote:
  	  | Quote: | 	 		  ...tires.  Between the Heat treated still legs and the larger tires, the
 cushion and energy absorbed on landing is great.  I really had trouble
 knowing when I was down and rolling when I first used the new setup.  You
 have to experiment with the air pressure a bit.  Too much air pressure
 will throw you back into the air...
 This reminds me of a totally different question I've been meaning to ask.
 My UltraStar, of course, has absolutely no flex to the gear legs, so the
 tires are it.  I have Freebird wheels and brakes, with tubeless wheelbarrow
 tires.  With fairly low air pressure I get adequate cushioning, but the
 other day I was turning tight on the runway with the help of brakes, and
 apparently twisted the tire right on the wheel enough to make it go
 completely flat.  The tire never came completely off the wheel, so I was
 able to reinflate it with no problem.  Is this a common problem?  How do
 you deal with this... should I be using tubes?
 -Dana
   Diplomacy: Saying "nice doggy" until you find a rock.
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Wed Feb 20, 2008 6:54 pm    Post subject: Tires, was: Re: Building your own gear legs |
				How do
  	  | Quote: | 	 		   you deal with this... should I be using tubes?
  -Dana
 Dana:
 That is what I would do.
 I run tubes in my tires.
  _________________ John Hauck
Titus, Alabama |
		Wade Lawicki
  Joined: 27 May 2007 Posts: 31 Location: Nashville Tn.
				 Posted: Wed Feb 20, 2008 8:35 pm    Post subject: Re: Tires, was: Re: Building your own gear legs |
				Dana,
       I have had the same problem on several planes. Tubes help keep it from coming off the bead but, then sometimes from using low psi you will spin the tire on the rim tearing up the stem of the tube. You can usually fix that by drilling 2 small holes in the bead of the rim and put small screws into the bead of the tire to keep them from spinning under heavy breaking but, from then on you will not be able to go tubeless.
                                                      Fly Safe,
        Wade
		Ed in JXN
				 Posted: Thu Feb 21, 2008 1:39 am    Post subject: Tires, was: Re: Building your own gear legs |
				Wade/All,
         No need to drill holes.  Go to a good hobby shop, especially one
 that sells nitro cars, and buy some 'tire glue'.  The stuff holds the slicks
 on my 1/4-scale sprinter during burn-outs, with no air pressure
 (foam-filled) (no, not sea-foam!).
 Ed in JXN
 MkII/503
		captainron1(at)cox.net Guest
				 Posted: Thu Feb 21, 2008 7:50 pm    Post subject: Tires, was: Re: Building your own gear legs |
				Its common if the air pressure is too low. I would go with custom gear legs. Slightly thinner, or longer with same thickness. There is really not much else you can do. I guess I would try wheels at low pressure with inners, but you can rip the stem off of them if the pressure is too low. Me I'd probably try to add some length through some adopter tube or sleeve to the gear. Don't know about your machine as I don't know what your gear looks like. But you can try the ideas they're free.
 Ron (TxAz)
 -Dana
 kugelair.com
		Dana
				 Posted: Fri Feb 22, 2008 4:04 am    Post subject: Tires, was: Re: Building your own gear legs |
				At 10:47 PM 2/21/2008, Ron wrote:
  	  | Quote: | 	 		  Its common if the air pressure is too low. I would go with custom gear
 I can't without major modifications on the US as the gear is absolutely
 rigid and triangulated, unlike the later Kolbs.  I'll probably look into
 the "tire glue".
 Not a closeup but you can sorta see it here:
 http://smg.photobucket.com/albums/v486/flyparafan/Kolb/?action=view¤t=DSC01307.jpg
 -Dana
   When authorities warn you of the sinfulness of sex, there is an important
 lesson to be learned. Do not have sex with the authorities.
