Soldering question--What am I doing wrong?
nuckollsr(at)cox.net
PostPosted: Mon Feb 27, 2006 7:34 pm    Post subject: Soldering question--What am I doing wrong? Reply with quote
I hope that adding to Bob's answer isn't too presumptuous....
Using insufficient heat/power is much more likely to damage stuff than
'too much'. Reason: if the iron isn't hot enough, or is so under
powered or under massed that it can't get the joint hot quickly, heat
can flow into easily damaged components & raise their temp to damaging
levels before the joint gets hot enough to flow solder. (Same thing can
happen if the joint or iron isn't clean.)
Dead on right sir. It's sorta like having your cubmaster having
you "start off easy" with a dull knife . . . lest you hurt yerself.
Saw more folks get buggered trying to force a cut with dull
knives than those who could concentrate on doing it right
because skill and not the tool was the limiting factor.
