drfred(at)suddenlinkmail. Guest
Posted: Wed Feb 13, 2008 7:06 am Post subject: Silpruf Window installation |
Dave;
Thanks for the write up on the windows. It looks like a good product
after reading the data sheet.
Three questions. , one request.
1. how many tubes does one need for doing the 4 windows?
2. best price /supplier to purchase?
3. I couldn't get the link to work for the video.
4. could you provide a close up picture of the finished edge?
Thanks.
Fred Williams
40515
Starting door fit
kearney(at)shaw.ca Guest
Posted: Wed Feb 13, 2008 7:55 am Post subject: Silpruf Window installation |
Hi Fred
Here is the link in a smaller form: http://tinyurl.com/2ndhr9
Dave's link was broken by a line break in the text.
Cheers
Les Kearney
#40643
C-GCWZ (Reserved)
ricksked(at)embarqmail.co Guest
Posted: Wed Feb 13, 2008 8:24 am Post subject: Silpruf Window installation |
I ordered 4 10 oz tubes, $68 including shipping total. If I have any left there is my building buddy Mr. Kaufmann who will most likely claim my leftovers. From what I read on the instructions, I'll need at least one tube after paint. Here's the link I bought it from.
http://www.nextag.com/silicone-sealant/search-html
Rick S.
40185
Dave(at)AirCraftersLLC.co Guest
Posted: Wed Feb 13, 2008 9:46 am Post subject: Silpruf Window installation |
Fred,
We bought 5 tubes and used 3 1/2. The final step was done several months
after the first, so one of the partially used tubes was wasted.
I get SilPruf from a company called Lowry's in Hayward, CA:
http://www.halowry.com. Late last year it was about $6/tube.
Les posted a better link to the video in another message:
Here are some pictures. The black all blends together so one picture is
edited and labled so you can see the different parts. Real lilfe looks more
like the unlabled picture.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
48.43 KB |
386 Time(s) |
49.02 KB |
360 Time(s) |
Posted: Wed Feb 13, 2008 10:58 am Post subject: Silpruf window installation |
Dave, Les and Rick.
Thanks for the information and pics. Zooming in on the pics gives
enough detail to see how the bead lines up on the outside. I think
with your help I can make it look good. I ordered 4 tubes from
Technology LK for $67. Now if I could quit this day job and get back to
work. How did they ever build an airplane before the internet? Musta
been real men and real airplanes.
Fred Williams
planesmith(at)hotmail.com Guest
Posted: Wed Feb 13, 2008 11:58 am Post subject: Silpruf Window installation |
Dave,
I would also like to throw in my thank you for sharing.
This discussion has been centered around using SilPruf on the side windows. Did you also use it on the windscreen?
Vern Smith (#324 lost some where between the fuselage and finishing)
> From: Dave(at)AirCraftersLLC.com
| Quote: | To: rv10-list(at)matronics.com
Subject: RE: Silpruf Window installation
Date: Wed, 13 Feb 2008 09:41:31 -0800
Fred,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Need to know the score, the latest news, or you need your HotmailŪ-get your "fix". Check it out. [quote][b]
Posted: Wed Feb 13, 2008 1:38 pm Post subject: Silpruf Window installation |
Vern,
I installed the windshield per the plans, then overlaid a thin fiberglass layup over the exposed bond at the joggle. The edge is painted gloss black to match the other windows.
The windsheild could be installed with SilPruf but it would require quite a bit of rework in order to create a joggle along the bottom edge. I wasn't quite prepared to do that. Maybe next time. The results would be very similar to the other windows.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Vernon Smith
Sent: Wednesday, February 13, 2008 11:53 AM
Dave,
| Quote: | From: Dave(at)AirCraftersLLC.com
Fred,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Posted: Thu Feb 14, 2008 7:37 am Post subject: Silpruf Window installation |
Dave,
Thanks for the additional explanation. I think installing the windows is one area there is a need for more information. The workmanship is highly visible and it's not like you can drill the hole out and use an Oops rivet.
Thanks again,
Vern
Date: Wed, 13 Feb 2008 13:30:53 -0800
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} Vern,
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
Dave,
