raddatz
Posted: Fri Feb 08, 2008 6:45 am Post subject: extra |
Just bought an Extra, Most fun I ever had flying but it takes a little getting use to the landings.
Steve Raddatz
| | - The Matronics Aerobatic-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Aerobatic-List |
FlyDad57(at)neo.rr.com Guest
Posted: Fri Feb 08, 2008 7:37 am Post subject: extra |
Steve,
Can you elaborate? What is it about the landings that takes getting used
to? What did you fly before? Just curious.
raddatz
Posted: Fri Feb 08, 2008 7:49 am Post subject: Re: extra |
I have got over 600 hours in RV's with 500 plus hours in taildraggers. My plane is a Extra 260 with the mid wing design. so when I'm on final I lose site of the runway at any speed under 80kts due to the angle of attack so what I have learned is to slip my landing from downwind right to the numbers and that seems to work well. But its still work in progress.
Posted: Fri Feb 08, 2008 8:10 am Post subject: extra |
Excellent! That's exactly the information I was looking for. Thank you!
peter(at)sportingaero.com Guest
Posted: Fri Feb 08, 2008 11:37 am Post subject: extra |
Steve,
I had a mid wing 300 for a while. The best technique I found was to fly
a curving approach if at all possible, and convert that to a large slip
as I lined up on final, with plenty of power. I held the slip to the
absolute last minute (probably 20' or below), straightened up, cut the
power and landed. On take off I would leave the ground at 80kt in the 3
point attitude, so I approached at 80kt. Any more and I would float down
the runway completely blind. I want to know that the airplane would land
as soon as I shut the throttle. Kicking off the slip was enough to give
a little 'flare' to stop the rate of descent. Speed control +2kt -0 on
final was key to a good landing, at light weights I could get it down to
75kt without arriving too much tailwheel first. Using this technique I
did land on a 900ft runway one day with plenty to spare (but there was a
25kt wind blowing) - the alternative was 25kt across 1800' or land 25
miles away! Once on the ground I would pick the tail up so I could see
where I was going and could brake quite heavily controlling the attitude
with the elevator down to about 20 kt.
Hope this helps, Peter
raddatz
Posted: Fri Feb 08, 2008 12:53 pm Post subject: Re: extra |
Peter that is beautiful, I also stand the tail during rollout. Thanks for the info I'm also landing at my airpark which is narrow for a blind landing, but its progressing nicely.
MONTY(at)bpaengines.com Guest
Posted: Fri Feb 08, 2008 1:07 pm Post subject: extra |
You guys all need some Cessna 195 time. Talk about BLIND--------
Monty Barrett
C-195
Pitts 12
Former Skybolt
raddatz
Posted: Fri Feb 08, 2008 4:31 pm Post subject: Re: extra |
Monty you could mount a video camera under the wing and a tv screen in the panel and still not affect useful load.
Monty, I'm going to put a full Slick ignition system on my extra 260 which has a 315hp IO-540 that you built, What model slick mag would you use because it has 23* degree bendix on it now and would you install duel impulse mags.
Steve Raddatz
