Lynn Matteson
Posted: Thu Feb 07, 2008 7:22 am Post subject: Need advice on TruTrak ADI |
I'm thinking of getting a TruTrak ADI, and need some input. At first
I was going to go with a 2-1/4" unit...due to room restrictions...and
keep my 3-1/8" electric turn coordinator. Now I'm thinking of going
with the 3-1/8" unit, as I see that it has a ball included...the
2-1/4" does not.
I would be removing my present 3-1/8" turn coordinator, and in its
place install the TruTrak 3-1/8" ADI. As I see it, I would still have
a ball, still have bank information, and gain pitch information, right?
What I'm trying to do is "buy some insurance" in the event that I get
stupid (again) and fly into IMC.
Lynn Matteson
flying w/470+ hrs
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Thu Feb 07, 2008 8:00 am Post subject: Need advice on TruTrak ADI |
Go for it Lynn. You won't be sorry. Mine works great and the factory
support is superb.
Deke
FlyboyTR
Joined: 04 Nov 2006 Posts: 215 Location: Mobile, Alabama
Posted: Thu Feb 07, 2008 8:24 am Post subject: Re: Need advice on TruTrak ADI |
Lynn,
I recently installed an ADI Pilot II autopilot. Please see the thread: http://forums.matronics.com/viewtopic.php?t=37409
The ADI provides pitch and roll information via electronic gyros, ball and DG (directional gyro...heading) information via GPS ( you can slave to the ADI through your GPS if it has the appropriate NMEA output...otherwise you will need to add the internal GPS). The heading will not show up until you are going 15-20 MPH. Please note the OD of the unit 3.4X3.4". This OD was slightly larger than the instrument the ADI replaced...this was an issue and I had to shift 6 switched down 1/8" for clearance.
I purchased my unit from Jim at www.Oxaero.com He is located in Oxford, MS. Jim was very helpful, provided detailed responses to my questions and was a pleasure to work with. ...also saved me a few $$$.
I have been very pleased with my system. One of our local KF4 pilots (Catz...Dick M.) recently installed the ADI in his plane. He is also very happy with it. Hope this helps!
Travis
_________________ Travis Rayner
Mobile, AL
Skystar Vixen, N-789DF
Continental IO-240, Prince P-Tip Prop
ADI-II Autopilot
AnyWhereMap Navigation with weather
www.enotam.net (My Flying Info Website) |
fredshiple(at)sbcglobal.n Guest
Posted: Thu Feb 07, 2008 8:54 am Post subject: Need advice on TruTrak ADI |
Lynn
I recently installed the ADI after flying with it in a friends plane. It's well worth the price. Tru Trak was as excellent support resource in my installation.
Fred
[quote]I'm thinking of getting a TruTrak ADI, and need some input. At first
msm_9949(at)yahoo.com Guest
Posted: Thu Feb 07, 2008 12:06 pm Post subject: Need advice on TruTrak ADI |
Lynn,
I made the same decision after my ill-advised IMC adventure on the way home from OSH last year. Did not know that the 2 1/4" doesn't feature a ball, but it makes sense as small as it would have to be. That complicates things for me, however, having no 3 1/8" openings to spare and little room to add a new hole. I was hoping to pick one up at Sun-n-fun in April but don't really want to have to reconstruct my panel to accommodate it.
I see no down-side for you in replacing turn-coordinator with ADI.
Lynn Matteson <lynnmatt(at)jps.net> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson
I'm thinking of getting a TruTrak ADI, and need some input. Be a better friend, newshound, and [quote][b]
FlyboyTR
Posted: Thu Feb 07, 2008 12:24 pm Post subject: Re: Need advice on TruTrak ADI |
As an FYI...if the 2" unit would accommodate your panel, you could get a free standing ball/bank indicator. They attached directly to the face of your panel. Aircraft Spruce has them for around $30-40.
http://aircraftspruce.com/menus/in/bankindicators.html
This would be a simple fix and allow you to use the 2" ADI.
Travis
Mobile, AL
ADI-II Autopilot
Lynn Matteson
Posted: Thu Feb 07, 2008 1:21 pm Post subject: Need advice on TruTrak ADI |
I'd need to move my starter button to install the 2'' unit, and keep
my TC. Or put the smaller unit where the TC is now and have to make
a reducing adapter. At $200 more for the 2", and needing to move the
starter, it makes better sense for me to go with the larger unit.
Good suggestion, though, Travis.
Lynn Matteson
flying w/470+ hrs
On Feb 7, 2008, at 3:24 PM, FlyboyTR wrote:
Travis
Travis Rayner
Mobile, AL
IFR with Autopilot
http://forums.matronics.com/viewtopic.php?p=162871#162871
N369LM |
Lynn Matteson
Travis, Deke, Fred, and Marco-
Thanks for the info and suggestions. In looking at the specs for the
TC that I'll be removing, I see that it is 3-3/8" x 3-3/8", and the
ADI that I'll be going with is (like you said for the ADI autopilot,
Travis) 3.4"x 3.4". I think that'll be close enough for government
work. : ) I'm sure that I've got enough spacing already between
instruments to allow installation, but I'll plan on extra time to
install if it comes time for some metallic surgery. I've got my
Garmin 296 home with me now, and I just ran through the instructions
for getting the 4800 baud rate set. I hope this doesn't affect my
GPS's operation while I'm waiting for the "Big Brown Truck" to
arrive. I'll check with TruTrak when I place my order.
Lynn Matteson
flying w/470+ hrs
On Feb 7, 2008, at 11:24 AM, FlyboyTR wrote:
Lynn,
few $$$.
Travis
Travis Rayner
Mobile, AL
IFR with Autopilot
http://forums.matronics.com/viewtopic.php?p=162834#162834
N369LM |
FlyboyTR
Posted: Thu Feb 07, 2008 1:30 pm Post subject: Re: Need advice on TruTrak ADI |
Lynn,
You're welcome! Sounds like you are on the right track so that you end up with the larger unit. ...that would be my choice.
Travis
Mobile, AL
ADI-II Autopilot
Posted: Thu Feb 07, 2008 1:43 pm Post subject: Need advice on TruTrak ADI |
Yeah, I have one of those Travis. I was hoping to replace it with the ADI. So either way, I need another hole in the panel. It's tight, as you can see.
FlyboyTR <flyboytr(at)bellsouth.net> wrote:
[quote]--> Kitfox-List message posted by: "FlyboyTR"
Travis
Travis Rayner
Mobile, AL
IFR with Autopilot
Read Be a better friend, newshound, and
55.37 KB |
534 Time(s) |
Guy Buchanan
Posted: Thu Feb 07, 2008 5:00 pm Post subject: Need advice on TruTrak ADI |
At 01:40 PM 2/7/2008, you wrote:
| Quote: | Yeah, I have one of those Travis. I was hoping to replace it with
Marco,
Check out ACS. They have balls that mount to the face of the
panel. You could put the ADI where the 2" ball is now, and put a face
mount ball below it. Plenty of room.
Guy Buchanan
San Diego, CA
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Catz631(at)aol.com Guest
Posted: Fri Feb 08, 2008 5:58 am Post subject: Need advice on TruTrak ADI |
Marco,
I removed my 2" ball and installed the UMA airspeed in that hole then installed the TruTrac ADI(with GPS &antenna) where the old 3 1/4 " airspeed was. It works great and everything is within a 6" space.A Garmin 396 is next to the ADI Dick Maddux
Fox 4-1200
Pensacola,Fl
Who's never won? Biggest Grammy Award surprises of all time on AOL Music.
