		Sprayers(at)aol.com Guest
				 Posted: Mon Feb 04, 2008 7:35 am    Post subject: cleveland parking brake no hold? |
				Does any one have any idea why my cleveland parking brake does not hold  (after I land )and put the brakes on.  The brake will hold for few minutes  and then slowly release as time goes on. My brake works PERFECT if I  put the brakes on when the HR2 is in the hangar and has  not flown for some  time.  It  will hold for couple days. There are no leaks and I have  pumped 10 gallons of fluid up through the brakes the last year or so. I donot  have any loops in the hyd lines that go down. I have taken the brake loose  at the wheel and taped on it etc. I have also run the brake lines out of  the heat (forward of the firewall) and they come through firewall at bottom  corner behind engine mount. Remember they work perfect when the airplane has  been in hangar and not flown. What is going on here?  Thanks  Bill
 Who's never won?  Biggest Grammy Award surprises of all time on AOL Music.
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		denis.walsh(at)comcast.ne Guest
				 Posted: Mon Feb 04, 2008 7:55 am    Post subject: cleveland parking brake no hold? |
				Check the installation angle.  These only fully shut off when the clock position of the arm is in some funky, non intuitive angle.  got fo the web site and it will show you the right clock.  By no means the only suspect but a good place to start.
 On Feb 4, 2008, at 8:27 , Sprayers(at)aol.com (Sprayers(at)aol.com) wrote:
 [quote]  Does any one have any idea why my cleveland parking brake does not hold (after I land )and put the brakes on.  The brake will hold for few minutes and then slowly release as time goes on. My brake works PERFECT if I put the brakes on when the HR2 is in the hangar and has  not flown for some time.  It  will hold for couple days. There are no leaks and I have pumped 10 gallons of fluid up through the brakes the last year or so. I donot have any loops in the hyd lines that go down. I have taken the brake loose at the wheel and taped on it etc. I have also run the brake lines out of the heat (forward of the firewall) and they come through firewall at bottom corner behind engine mount. Remember they work perfect when the airplane has been in hangar and not flown. What is going on here?  Thanks Bill
 href="http://www.matronics.com/Navigator?Rocket-List">http://www.matronics.com/Navigator?Rocket-List
		Vince Frazier
				 Posted: Tue Feb 05, 2008 7:14 am    Post subject: cleveland parking brake no hold? |
				How hot do your brakes get? Hot enough to heat the hyd. fluid?  Could it
 be cooling and contracting and causing the brake release?
  _________________ Vince Frazier
3965 Caborn Road
Mount Vernon, IN 47620
812-464-1839 work
812-985-7309 home
F-1H Rocket, N540VF
http://vincesrocket.com/ |
