Update: Strange alternator behavior at Startup
nuckollsr(at)cox.net
PostPosted: Mon Feb 27, 2006 1:40 pm    Post subject: Update: Strange alternator behavior at Startup Reply with quote
At 02:23 PM 2/27/2006 -0500, you wrote:
<mstewart(at)iss.net>
Just as a reminder,
This behavior does not exist when OAT is above 40F OR is it is an
already warm engine.
On that same cold day Saturday, I started the warm engine at 400rpm and
it was charging immediately. There was no need to raise the rpm. Its
definitely temperature related.
Aha! Great data point. If a regulator designer was trying
to be really clever, the delayed turn on would be not only
related to RPM (stumbling engine) but temperature too (cold
weather is the hardest time to start).
