Posted: Thu Jan 17, 2008 6:39 am Post subject: Controlling defrost fans |
I have a pair of 1.5"x1.5" fans (Radio Shack 273-240) mounted forward of the instrument panel on my 6A slider - think about the intersection of the support bulkhead parallel and forward of the instrument panel and the ribs that point aft that support the top of the instrument panel in three places.
I am wondering if a straight on-off switch is sufficient or should I put in a rheostat to control the fan speed? KISS would dictate that a simple on-off switch would work - but has anyone out there wished for a half-speed?
Here on the DelMarVa peninsula - I'm certain that I'll need it on a regular basis
Ralph
ronlee(at)pcisys.net Guest
Posted: Thu Jan 17, 2008 7:10 am Post subject: Controlling defrost fans |
A rheostat probably has the same numbers of wires but you can turn it.
Hardly seems harder and it does offer flexibility.
Ron Lee
Dale Ensing
Posted: Thu Jan 17, 2008 7:17 am Post subject: Controlling defrost fans |
Ralph, I have a pair of 4" fans mounted in the top skin forward of the
instrument panel to blow on W/S of my 6A slider. No need for speed control.
Maybe the larger fans turn lower RPM. They are similar to cooling fans in a
computer tower.
BTW I use them in the summer to pull hot air from behind the panel and help
cool the avionics.
Dale
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
n616tb(at)btsapps.com Guest
Posted: Thu Jan 17, 2008 7:22 am Post subject: Controlling defrost fans |
I doubt that anything more than an on off switch would be needed. I
installed a fan in mine but have not needed it. Enough heat develops under
the panel that just having the opening in there has been sufficient. I park
in a hangar however so if you need to seriously defrost, than a simple on/
off switch would be all you would need.
My opinion of course.
[quote] --
Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Thu Jan 17, 2008 7:23 am Post subject: Controlling defrost fans |
I have the same fans, but I just let them run all the time. No switch...
Ted French C-FXCS
RV-10 Flying
_________________ Ted French
RV-10 fuselage |
DOUGPFLYRV(at)aol.com Guest
Posted: Thu Jan 17, 2008 8:36 am Post subject: Controlling defrost fans |
RALPH, WE HAVE HAD FANS IN THE LAST 3 RV'S WITH JUST THE ON/OFF SWITCH. U SURE WOULDN'T BE ABLE TO HEAR THEM.
DOUG PRESTON
N372RV
Start the year off right. Easy ways to stay in shape in the new year.
Knicholas2(at)aol.com Guest
Posted: Thu Jan 17, 2008 9:26 am Post subject: Controlling defrost fans |
I have several computer cooling fans in my RV9A on the wind screen. I only have on/off, they are very quiet and also serve as a window defroster. I see no need for a rheostat.
Kim Nicholas
In a message dated 1/17/2008 6:40:48 A.M. Pacific Standard Time, recapen(at)earthlink.net writes:
| Quote: | I am wondering if a straight on-off switch is sufficient or should I put in a rheostat to control the fan speed? KISS would dictate that a simple on-off switch would work - but has anyone out there wished for a half-speed?
n212pj(at)gmail.com Guest
Posted: Thu Jan 17, 2008 10:33 am Post subject: Controlling defrost fans |
Wouldn't the variable speed or rheostat be a good source for noise problems in the old headset? Best just use an on/off switch. Those fans are so quiet, who cares if they run full tilt, but they should be able to be turned off in case amps need to be shed, small amount of amps, though.
John Jessen
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Knicholas2(at)aol.com
Sent: Thursday, January 17, 2008 9:24 AM
To: rv-list(at)matronics.com
Subject: Re: RV-List: Controlling defrost fans
Kim Nicholas
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Carl
Posted: Thu Jan 17, 2008 3:20 pm Post subject: Controlling defrost fans |
Is there any chance of getting a picture? What a great idea.
_________________ Carl Bell
Building N947CB
RV 7A |
Dale Ensing
Posted: Thu Jan 17, 2008 4:52 pm Post subject: Controlling defrost fans |
I'll try to take a couple of good pictures tomorrow and send.
Dale
RV-6A
Aero Plantation
Weddington NC |
gmcjetpilot
Posted: Fri Jan 18, 2008 11:16 am Post subject: Controlling defrost fans |
I think ON/OFF is fine, but if you want to control it try a
PWM (pulse width modulation) control "rheostat".
http://solorb.com/elect/pwm/pwm1/
There are hobby kit's you can buy with all the parts
and board, as well (google it). George
>From: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
| Quote: | Subject: Controlling defrost fans
| Quote: | I put in a rheostat to control the fan speed? KISS would dictate
there wished for a half-speed? Thanks, Ralph
mikerv6a(at)ao.com Guest
Posted: Mon Jan 21, 2008 7:50 pm Post subject: Controlling defrost fans |
Here is a simple two-speed fan control using an spdt switch. I'm using a
fan from DigiKey, cat no. 603-1055-ND that's 80mm square and 25.4mm
thick, about 3.15" x 1". It has ball bearings and relatively high airflow
for its size. Rated power at 12V for this fan is 6 watts. I measured fan
current at about 0.52A at 12.0 volts. The relationship between voltage and
current was close to linear down to 6V, and the fan continues to run at
still lower voltage. I chose 8V as a target votlage for "slow" speed, and I
found fan current to be about 0.33A at this voltage. Speed of these fans is
easily controlled either by providing variable voltage or by inserting a
resistor in series with the fan circuit. I used a 15-ohm 10-watt resistor
having an aluminum housing which includes tabs for mounting on a couple of
screws. This results in about 8.5 volts on the fan with 13.5V power bus
voltage. Power dissipation in this resistor is calculated to be about 1.7
watts. The reason for my "oversizing" the power rating of the resistor
I selected is that the built-in mounting provision for the 10W resistor is
very convenient. The resistor is DigiKey catalog no. 810F15RE-ND.
(Low Speed) Resistor
O--------------/\/\/\/------
-------------/ O (OFF) |
spdt switch |
w/ center-off O---------------------------
------------------------------- FAN--------
(Full Speed)
Mike Linse
RV-6A (canopy...)
Corvallis, OR
Carl
Posted: Mon Feb 04, 2008 5:39 pm Post subject: Controlling defrost fans |
Mike,
Did you get a chance to make a couple of pictures, I bought the fans and
would love to see your installation. Thx C
Carl W Bell
New Venture Consulting
Mobile: 803.640.2760
www.newventureconsulting.com
carlbell(at)gforcecable.com
Building N947CB
RV 7A |
