		mneufeld(at)verizon.net Guest
				 Posted: Wed Jan 30, 2008 7:36 pm    Post subject: Fuel vents |
				Do your fuel vent lines turn forward into the air stream, or are they cut 45* toward the air stream?  Would that make a difference?
 My fist flight, HR II, N145HR, Fox Field, Lancaster, Ca, is about two weeks away.  I'm ready now but my Garmin 330 transponder has an AD which requires the unit be sent to Garmin.  Turn around is two long weeks.  I discovered the AD when I inquired about the pitot static sytem check.  The AD requires compliance after the required transponder pitot static system check.
 FAR 91.205(a) (civil aircraft) require all the equipment in the plane to be operable at the time when the airworthiness certificate is issued?  That's the way I understand it.... even AD's?  I now about FAR 91.213 approved equip list, but that's not applicable.
 Mark Neufeld
 Date: 2008/01/04 Fri PM 01:00:28 CST
 To: rocket-list(at)matronics.com
 Subject: Fuel vents
  |  | - The Matronics Rocket-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Rocket-List |
		lesdrag(at)aol.com Guest
		jrstone(at)insightbb.com Guest
				 Posted: Thu Jan 31, 2008 10:40 am    Post subject: Fuel vents |
				Hey Mark,
 Tell me more about the 330 AD.  Or send me in the right direction.
 Jim Stone
 Louisville
				 Posted: Thu Jan 31, 2008 5:16 pm    Post subject: Fuel vents |
				Jim,
 The Garmin 330 transponder AD is: mandatory, covered under warranty, and required compliance after the biannual pitot static system check.
 I went to the Garmin web site and pasted the following service notice located in their "Service Alert" file.
 Today, Garmin is providing a software update (v3.06) for its GTX 330, 330D, 33 and 33D Mode S
 transponders. The company has issued mandatory service bulletins, requiring aftermarket customers and
 OEMs to install the v3.06 software on these products. The v3.06 software update supersedes all previous
 updates related to FAA Airworthiness Directive 2004-10-15, which addresses a potential air-to-air safety issue
 between GTX 330/330D-equipped aircraft and those installed with various TAS, TCAD and TCAS I
 equipment.
 AD 2004-10-15 lists a potential safety issue in which Garminâs Mode S transponders may intermittently
 suppress an air-to-air interrogation from aircraft using certain collision-avoidance systems. While pilots
 flying with respective Garmin equipment will see nearby aircraft via TIS, it is possible that they may not be
 âvisibleâ to certain traffic-awareness systems in nearby aircraft. Garmin equipped aircraft remain
 appropriately âvisibleâ within the normal operating range of FAA Terminal and ARTCC RADAR.
 The AD specifies corrective action, including installation of the software update at a certified repair center.
 Garmin encourages its customers to contact their avionics dealer or the companyâs field-service engineering
 staff with any questions or concerns regarding the AD.
 Date: 2008/01/31 Thu PM 12:30:56 CST
 Subject: Re: Fuel vents
 Hey Mark,
 Jim Stone
 Louisville
				 Posted: Sat Feb 02, 2008 10:17 am    Post subject: Fuel vents |
				Jim,
 My fuel vents face forward also, thanks for the info.
 I went to the Garmin web site and found the AD under their "Service Alert" file, posted Aug 27, 2004, and pasted it below.  Looks like it also applies to the 330D, (European mandate mode S level 2) 33 and 33D transponders (remote mounted transponders).
  SERVICE NOTICE
 From: Bob Haase, Aviation Product Support Manager, Garmin International
 Re: Software Update for Garmin Mode S Transponders
 Date: August 27, 2004
 equipment.
 This is the second time I sent this message. The first message may have not been posted .... I never saw it on the Matronics web site.
 Mark
 Hey Mark,
 Jim Stone
 Louisville
				 Posted: Sat Feb 02, 2008 6:39 pm    Post subject: Fuel vents |
				Thanks Mark,
 I'm thinking my unit is ok since it is only 6 months old.
 I guess I should find out for sure.
 Jim
