tjs22t(at)verizon.net Guest
Posted: Sun Jan 27, 2008 7:14 pm Post subject: test flight |
I know there are circumstances that prevent some builders from doing the
first flight, but the best advice received from ZAC came from Roger who told
me to never allow anyone else to make the first flight. Boy was he correct.
I'll not make crass comparisons with other "firsts," but you will never
forget this one experience - you, and you alone, have created magic.
jeff
| Quote: | Bill - no hangups. My FAA inspector knew I was not going to fly off my 40
hours. I've had a couple of guys step forward and they are working on it
one weekend at a time.
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Mon Jan 28, 2008 9:00 am Post subject: Re: test flight |
Jeff,
You are correct in that there can be few more satisfying experiences than taking an airplane that you built into the sky for it's first flight. I congratulate you on such a great accomplishment.
I hope that not everyone takes Roger's advice. It would be more correct to say that builders who have the experience and currency to deal with unexpected and "different" flying characteristics should be able to conduct the first flight safely. If I were the builder I would want to try to prepare myself to be able to conduct that momentous flight, but I wouldn't let my ego or personal desires get in the way of common sense.
In my career I have just happened to be on the scene on two occasions when a homebuilder attempted the first flight in his creation and crashed in the attempt. Fortunately both survived, but only one plane was rebuildable.
The first guy was a private pilot who hadn't flown in 5 years and was attempting to fly a taildragger for the first time that had a prop that rotated in the opposite direction to the typical continental or lycoming. He lost control on the takeoff roll and went off the runway, hit a snowbank and flipped upside down.
The second was a guy who had maybe 200 hours in a Cessna 150. He was flying a low wing speedy looking thing (don't remember what) and over-rotated on takeoff causing the tail to bang the runway hard. The plane leapt into the air causing him to overreact by jamming the nose down at which point he impacted the runway, sheared the nosewheel and prop and slid along the pavement until coming to rest.
Assuming that my first (and subsequent flights) are successful I hope to be able to use my plane help some other guys get ready to fly their own... There is no substitute for recent experience in type.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
naumuk(at)alltel.net Guest
Posted: Mon Jan 28, 2008 3:37 pm Post subject: test flight |
T.J and Scott-
I wasn't planning on having someone fly off all 40 hrs, just have an
exceptional pilot I know who's done the shakedown runs on all kinds of
planes get it in the air and let me know what rigging changes are needed (If
any). Then, after the rigging is right, have him ride right seat for a
couple of hours and give me a heads up on the handling quirks. In 24
years/SEL, I've never flown a low wing plane, and can't rent so much as a
Cherokee around here.
As the insane asylum inmate said, "I'm crazy, not stupid!" Pretty much
sums up homebuilding.
Bill
Posted: Mon Jan 28, 2008 3:50 pm Post subject: test flight |
Don't you need some sort of FAA exemption to have a passenger/copilot in the
plane during the 40 hour fly off?
-- Craig
Tim Juhl
Posted: Mon Jan 28, 2008 4:45 pm Post subject: Re: test flight |
The regs say only required crewmembers... I don't know if you could stretch that interpretation to cover such a situation.... I'd pose it to the EAA and get their input.
CFII
Champ L16A flying
dredmoody(at)cox.net Guest
Posted: Mon Jan 28, 2008 5:20 pm Post subject: test flight |
Here's my take on the issue. You could not stretch the regs to claim that you need a passenger or copilot to establish the plane's performance with two souls on board. Dead weight in the right seat would definitely suffice. You could probably bring a safety pilot if your flight was scheduled to test the HSI or other IFR gear under simulated IMC. I will ask for a copilot allowance for setting and calibrating the AOA system of my glass panels. It takes the pilot to fly into and through a stall and recovery several times to establish the critical AOA speed in the existing conditions. It also requires flying a zero G parabola to establish a zero lift reference. In those two exercises, the calibrate button must be pressed at the exact critical moment called for in the calibration procedure. In my opinion, that would be safest with two on board. I can't think of anything else in the test flight hours that would justify a second crew member. Maybe checking the coffee maker?
Dred
Posted: Mon Jan 28, 2008 6:51 pm Post subject: test flight |
All-
None of the recent posts reflects my intent. The shakedown hours need not count towards the 40 "Fly Off" hours, and the test pilot I spoke of is a CFII.
To keep it short, I intend to do whatever is necessary and legal to give me the best chance of flying my project safely.
Bill
Gig Giacona
Posted: Tue Jan 29, 2008 6:42 am Post subject: Re: test flight |
I'm a little confused by your phrasing here Bill. When you don't say, "The shakedown hours need not count towards the 40 "Fly Off" hours..." It sounds like you think if you don't call it Phase One flight it isn't. That isn't the case. It's a Phase One flight until you have flown off the hours and have entered Phase Two. And the regulations are pretty clear that in order to have a second pilot in the aircraft during Phase One it has to be approved by the FAA and in the operating limitations.
The fact that the test pilot is a CFI isn't really at issue. If he is a smart CFI he isn't going to risk his certificates doing something that, if caught, would certainly lead to some level of FAA action against him.
I don't know where you live but if there is another 601 anywhere near by you could get some dual with him in it and he could also use this time to layout any handling differences in your plane and the one you get dual in.
| naumuk(at)alltel.net wrote: | All-
Bill
601XL Under Construction
Jaybannist(at)cs.com Guest
Posted: Tue Jan 29, 2008 8:08 am Post subject: test flight |
I agree. The 40-hour "fly-off" IS the shakedown, not a different phase. "Fly-off" or "shakedown", which ever your want to call it, starts when the wheels first leave the ground. The FAA wants to make sure your "homemade" contraption is safe to fly before you risk the life of an innocent passenger. Making exceptions invites abuse of the policy. That said, I do believe the FAA should be realistic about allowing another person aboard who is not just a passenger, but an actual co-pilot, technical adviser or really essential helper. I fully expect to appeal to them for such an exception during my 40 hours of flight testing.
Jay in Dallas 601XL N2630J "Lil Bruiser"
"Gig Giacona" <wr.giacona(at)suddenlink.net> wrote:
> All-
> Bill
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=161059#161059
victorbravo(at)sbcglobal. Guest
Posted: Tue Jan 29, 2008 8:58 am Post subject: test flight |
Please be careful about recommending that the builder perform the test
flight. Sometimes yes, sometimes no. Depends on a lot of factors.
We just lost a 601XL here recently on the first flight, our EAA chapter
lost two very enthusiastic members, and a very good man nearly lost his
life... mostly because he did the first flight himself (and made
incorrect decisions related to the first flight). Only by the grace of
God, he escaped with a couple of scrapes.
He just simply was not the right guy to do the first flight, and his
actions before and during an emergency (912 failure) resulted in a total
loss instead of an otherwise minor incident. And this guy was no
slack-jawed hillbilly either, he is an extremely intelligent
professional who had taken great pains to do almost everything else that
day in a safe manner, flew a recommended "test card", flew very
methodically, etc.
Some builders should be OK to do the first flight on some airplanes, in
some conditions, and with some things going in his/her favor.
dj45
Posted: Tue Jan 29, 2008 11:58 am Post subject: Re: test flight |
Bill, It may not be exactly legal, I think I would have the test pilot take the plane to a non towered field and do your thing. And don't do a lot of bragging about how well things went.
After you are comfortable, do your 40 hrs. at your home field.
I don't even have my license yet and have to watch my partner/sister fly off the time before I can even use it for my training. You don't have it all bad.
Good luck and the first flight is a gas.(I would imagine)
_________________ Do not archive
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
Aerolitellc(at)aol.com Guest
Posted: Tue Jan 29, 2008 12:27 pm Post subject: test flight |
Just remember if you do anything like that you have 0 insurance should something happen. And I doubt any CFI will say he was flying and have that on his record should things go wrong.
Start the year off right. Easy ways to stay in shape in the new year.
Gig Giacona
Posted: Tue Jan 29, 2008 12:54 pm Post subject: Re: test flight |
For someone who doesn't even have your license yet you sure seem quick to have someone else put theirs up for grabs.
And those non-towered fields are often chocked full of people that will report you.
| dj45 wrote: | Bill, It may not be exactly legal, I think I would have the test pilot take the plane to a non towered field and do your thing. And don't do a lot of bragging about how well things went.
Good luck and the first flight is a gas.(I would imagine) |
dj45
Posted: Tue Jan 29, 2008 2:49 pm Post subject: Re: test flight |
Well, I certainly did ask for that.
Dan Stanton
N801S CH 801
N226BS CH701
N24DS CH750 |
Posted: Tue Jan 29, 2008 4:15 pm Post subject: Test flight |
All-
As I said, I would do all that was LEGAL to ensure my confidence. I'm not looking for ways to buck the system.
Is there anything illegal with letting another qualified person make one or more flights, then passing on his findings before the owner gets in the cockpit? Start the 40 hrs from that point? I'm interested in the responses from flying posters, but don't want to drag this thread on.
Over and out.
Bill
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
Tim Juhl
Posted: Tue Jan 29, 2008 4:24 pm Post subject: Re: test flight |
Let me give you a CFI's perspective. In short, we are supposed to know better. The FAA would show little sympathy to a CFI shown to be bending the rules.
Another issue that comes up is pilot in command. As a CFI, even if I am not acting as pilot in command by legal definition, I am expected to do my best to exert some influence over the flying pilot to conduct the flight in a safe manner. Numerous legal cases have found that pilot "passengers" with higher ratings than the flying pilot have some culpability when it comes to accidents and etc. The attitude is: "he should have done something."
Personally, I might use my personal aircraft to help a fellow prepare to fly his own 601 but I would refuse to give him any dual in his plane until the required hours were flown off. I have had a CFII for 23 years and plan to keep it.
CFII
Champ L16A flying
Tim Juhl
Posted: Tue Jan 29, 2008 4:35 pm Post subject: Re: test flight |
Reply to Bill's last post - I don't believe the 40 hours has to be flown off by the same person. If you have a test pilot make the first few flights and then take over, his hours should count towards the total.
CFII
Champ L16A flying
Posted: Wed Jan 30, 2008 8:40 am Post subject: Test flight |
hi Bill,
Nothing wrong with having someone that's flown a Piper PA28 or equal do
your first flight if necessary. I'd recommend you rent a Piper and get a
CFI to get you comfortable with it and then transition to your 601. The
flight characteristics are similar, but the 601 is a bit lighter and
more responsive, and just easier to fly. Putting someone in before
you isn't going to make it any easier for you to fly it. Perhaps
there's someone in PA that has a HDS that would be willing to get you
transitioned.
Larry McFarland
Bill Naumuk wrote:
| Quote: | All-
Over and out.
Bill
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
Gig Giacona
Posted: Wed Jan 30, 2008 9:10 am Post subject: Re: Test flight |
No Bill there's nothing wrong with that. In fact it is a great idea. There is no reason though not to count the time the first pilot flies in the 40 hours.
Over and out.
Bill
� � do not archive
Bill Naumuk
Townville, Pa.
HDS Fuse/Corvair
Posted: Wed Jan 30, 2008 11:13 am Post subject: Test flight |
| Quote: | Perhaps
transitioned.
All Bill (and Lynn too) have to do is get the 125 or so miles to the
southeast and show up in Carlisle, PA.
The subs and pizza are on them, the HDS on me.
CAVU Jeff Small in southcentral PA where winds are 30 gusting to 40+
