Mounting RV8 - F-827c flap fairing after the floor is insta
algrajek
PostPosted: Mon Jan 28, 2008 8:06 am    Post subject: Mounting RV8 - F-827c flap fairing after the floor is insta Reply with quote
I did the same thing. Use Pop rivets and no one will ever know the difference.
Al Grajek
[quote] Date: Sun, 27 Jan 2008 15:52:02 -0800
To: rv8-list(at)matronics.com
Subject: Mounting RV8 - F-827c flap fairing after the floor is installed
.ExternalClass nobr {white-space:nowrap;} .ExternalClass ol {list-style-type:decimal;margin-bottom:10;} .ExternalClass u {text-decoration:underline;} .ExternalClass s {text-decoration:line-through;} .ExternalClass p {;} .ExternalClass dd p {margin-left:0;margin-bottom:0;} .ExternalClass ol li p {margin-bottom:0;} .ExternalClass address {font-style:italic;color:blue;} .ExternalClass i {font-style:italic;} .ExternalClass h6 {font-weight:bold;font-size:xx-small;margin-bottom:10;} .ExternalClass h5 {font-weight:bold;font-size:x-small;margin-bottom:10;} .ExternalClass h4 {font-weight:bold;font-size:small;margin-bottom:10;} .ExternalClass h3 {font-weight:bold;font-size:medium;margin-bottom:10;} .ExternalClass dir li p {margin-bottom:0;} .ExternalClass h2 {font-weight:bold;font-size:large;margin-bottom:10;} .ExternalClass b {font-weight:bold;} .ExternalClass h1 {font-weight:bold;font-size:x-large;margin-bottom:10;} .ExternalClass caption {text-align:center;} .ExternalClass a {text-decoration:underline;color:blue;} .ExternalClass ul li ul li ul li {margin-left:0;margin-right:0;margin-bottom:0;} .ExternalClass menu {margin-bottom:10;} .ExternalClass menu li p {margin-bottom:0;} .ExternalClass sup {vertical-align:sup;} .ExternalClass {margin-left:0;font-weight:normal;color:black;font-size:14pt;font-family:Serif;margin-right:0;} .ExternalClass ul li ul li ul {list-style-type:square;} .ExternalClass blockquote {margin-left:35;margin-bottom:5;margin-right:35;} .ExternalClass samp {font-size:small;font-family:Monospaced;} .ExternalClass cite {font-style:italic;} .ExternalClass sub {vertical-align:sub;} .ExternalClass em {font-style:italic;} .ExternalClass ul li p {margin-bottom:0;} .ExternalClass ul li ul li {margin-left:0;margin-right:0;margin-bottom:0;} .ExternalClass var {font-style:italic;font-weight:bold;} .ExternalClass table {border-style:outset;border-color:Gray;} .ExternalClass dfn {font-style:italic;} .ExternalClass menu li {margin-left:0;margin-right:0;margin-bottom:0;} .ExternalClass strong {font-weight:bold;} .ExternalClass ul {list-style-type:disc;margin-bottom:10;} .ExternalClass center {text-align:center;} .ExternalClass ul li ul {list-style-type:circle;} .ExternalClass kbd {font-size:small;font-family:Monospaced;} .ExternalClass dir li {margin-left:0;margin-right:0;margin-bottom:0;} .ExternalClass ul li menu {list-style-type:circle;} .ExternalClass dt {margin-bottom:0;} .ExternalClass ol li {margin-left:0;margin-right:0;margin-bottom:0;} .ExternalClass li p {margin-bottom:0;} .ExternalClass strike {text-decoration:line-through;} .ExternalClass dl {margin-left:0;margin-bottom:10;} .ExternalClass tt {font-family:Monospaced;} .ExternalClass ul li {margin-left:0;margin-right:0;margin-bottom:0;} .ExternalClass dir {margin-bottom:10;} .ExternalClass tr {text-align:left;} .ExternalClass pre p {;} .ExternalClass dd {margin-bottom:0;} .ExternalClass th {padding-top:3;border-style:inset;padding-bottom:3;font-weight:bold;padding-left:3;text-align:center;border-color:Gray;padding-right:3;} .ExternalClass pre {font-family:Monospaced;margin-bottom:5;} .ExternalClass td {padding-top:3;border-style:inset;padding-bottom:3;padding-left:3;border-color:Gray;padding-right:3;} .ExternalClass td p {;} .ExternalClass code {font-size:small;font-family:Monospaced;} .ExternalClass small {font-size:x-small;} .ExternalClass big {font-size:x-large;} Fef: F-827c Dwgs 28 and 43 mounting flap fairing views DD and EE
Hello,
I permanently installed the floors thinking I had everything covered. Not quite, seems those seven holes on the bottom of the fuselage that have been staring back at me for several years belong to the flap fairing and I now cannot access them from inside the fuselage.
Removing the floor is not an option so I am wondering if someone has unique solution before I grab the pop rivets.
Vince H. (Finish)
I see the light at the end of the tunnel. Unfortunately this is the fourth tunnel in a row.
et=_blank>http://www.matronics.com/Navigator?RV8-List
p://forums.matronics.com
just rv8in
