Curt.Thompson(at)verizon. Guest
Posted: Thu Jan 17, 2008 9:45 pm Post subject: Autocad drawings for CH701 form blocks? |
Got my CH701 plans in the mail today. Yippee!!
Are there autocad drawings somewhere that I can use to make form blocks for the CH701? A draft-lady friend of mine says she can print them on a big plotter and tweak them so they are full scale. I’m thinking I could then glue the paper to wood to make the form blocks.
Curt
Redmond, WA – Building hours zero (0)
ch701builder
Joined: 07 Feb 2006 Posts: 119 Location: N38.9947,W105.1305,ALT. 9,100'
Posted: Fri Jan 18, 2008 4:59 am Post subject: Autocad drawings for CH701 form blocks? |
Curt
goto www.ch701.com
then click on Builders resources.
I have uploaded some DXF and PDF files that should help.
Also, there are not any drawings for the tail section on these drawings. I bought the tail as a kit, but everything else is by scratch.
(Also, just double check the drawings..before you cut..)
Actually while I am thinking about it, double check the top skin at the tail end. I think that it is not correct. My plans have 2 conflicting dims. and I think I went with the wrong one (of course)
Keith
CH701 -- scratch
N 38.9947
W 105.1305
Alt. 9,100'
randy(at)rjhebertassoc.co Guest
Posted: Fri Jan 18, 2008 5:36 am Post subject: Autocad drawings for CH701 form blocks? |
Curt
I drew the rudder ribs and spars in AutoCAD but quickly found out that it was much easier to simply draw the pattern out on the wood directly.
There is no way to assure your plotter will plot to the exact scale. There can be distortion. I didn't want to take the chance.
Using a Sharpie doesn't give you much accuracy though. But mine seemed to work out to the finished dimensions.
If you want the Rudder, I can send it to you I use LT2007 but can save it to any version.
Randall J Hebert
Randall J Hebert & Associates, Inc
Consulting Civil / Structural Engineers
Lafayette, Louisiana
PH 337-261-1976 - FX 337-261-1977
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Curt Thompson
Sent: Thursday, January 17, 2008 11:43 PM
Subject: Autocad drawings for CH701 form blocks?
Curt
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
cookwithgas
Posted: Fri Jan 18, 2008 6:23 am Post subject: Re: Autocad drawings for CH701 form blocks? |
[quote="Curt.Thompson(at)verizon."]Got my CH701 plans in the mail today. Yippee!!
Curt
You mean like this?
http://www.cooknwithgas.com/9_6_03_CuttingTemplates.jpg
http://www.cooknwithgas.com/9_6_03_RibTemplates.JPG
http://www.cooknwithgas.com/9_13_03_RibCollection.JPG
Curt - go one step further and draw the entire rib in AutoCadd and plot it out. Then glue it to some thin material so you can lay it on the aluminum and mark exactly where to cut. Also, drill all the holes in the aluminum right through the template - even the round corner holes where two cuts come together and you don't have to use a round file to file the intersection. It is quick and easy. My templates and forms have made 136 ribs to date and they are still in good shape. (they are loaned out right now making two identical 601XL's).
You have a good idea - stick with it.
Scott Laughlin
601XL/Corvair Finished & Flying
Posted: Fri Jan 18, 2008 7:12 am Post subject: Autocad drawings for CH701 form blocks? |
Scott,
Yes, I was thinking about making rib cutting templates like yours (yours are
for a CH601, correct?). Could I make the templates a little thicker and use
a laminating cutter bit and router to cut the aluminum blanks? I think I
saw that in the "Scratch Building Basics or Metal Aircraft" DVD.
Curt
Posted: Fri Jan 18, 2008 7:23 am Post subject: Autocad drawings for CH701 form blocks? |
Randall,
I have read somewhere that scaling a plot could be a problem. I specifically asked my draft-lady friend if she could independently scale the X and Y axis after making a test plot. She says yes. I haven’t used autocad for at least 20 years but she said she would help. Could you email me the files so I could look at them?
Curt
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Randall J. Hebert
Sent: Friday, January 18, 2008 5:21 AM
Subject: RE: Autocad drawings for CH701 form blocks?
Curt
[b]Randall J Hebert[/b]
[b]Randall J Hebert & Associates, Inc[/b]
[quote] [b]
Posted: Fri Jan 18, 2008 7:33 am Post subject: Autocad drawings for CH701 form blocks? |
Thanks Keith. I can't believe I didn't run across your site before. All
kinds of good info there. I think the plotter I have access to will plot up
to 48" wide (and virtually infinite length). I will double check the
measurements before using.
Curt
cookwithgas
Posted: Fri Jan 18, 2008 9:16 am Post subject: Re: Autocad drawings for CH701 form blocks? |
| Curt.Thompson(at)verizon. wrote: | Scott,
Curt |
Curt: I cut everything out with snips. My good friend David Barth always laughed at me every time he saw a picture like this:
http://www.cooknwithgas.com/6_7_04_BottomFuse.JPG
or this:
http://www.cooknwithgas.com/7_9_04_FirewallCutting.JPG
That's because David is the "Olfa-king." I never could figure out how to use the Olfa knife.
I enjoyed the careful work of cutting out a perfect part. Plus, it gets you ready for all those awkward cuts you have to make later when everything is assembled and you have to change something!
I think the router idea would make a huge mess but to each his own.
Good luck,
Scott Laughlin
Did I just say Finished & Flying? Let me pinch myself.
foxatgibsons(at)gmail.com Guest
Posted: Fri Jan 18, 2008 11:10 am Post subject: Autocad drawings for CH701 form blocks? |
hi all
i'm as we speak drawing out the small parts on cad to use on my milling center
it seems that some of the curve stn.data is developed for a batten or steel ruler other than that
it seems ok
peter
On Jan 18, 2008 7:28 AM, Curt Thompson <Curt.Thompson(at)verizon.net (Curt.Thompson(at)verizon.net)> wrote:
[quote] --> Zenith-List message posted by: "Curt Thompson" <Curt.Thompson(at)verizon.net (Curt.Thompson(at)verizon.net)>
Curt [quote][b]
davids601xl(at)yahoo.com Guest
Posted: Mon Jan 21, 2008 8:09 am Post subject: Autocad drawings for CH701 form blocks? |
LOL Olfa King? Thanks for that Scott but a bit
overstated.
I have used a router for cutting as stated here and it
works well when making many of the same parts blanks.
You have to make a set of cutting blocks. Much like
the form blocks but with the added material for the
flanges. It takes a bit of planning since you will
want to use the same tooling holes in the cutting
blocks as you do in the form blocks.
Then you can rough cut your parts blanks, stack 4 or
so in the cutting blocks sandwich and tighten them
down. Then use the router to trim off all the excess
material down to the edge of the cutting blocks. After
getting the cutting blocks set up,we made a complete
set of 701 nose rib blanks in just a few minutes this
way. And of course if you do a good job on your
cutting blocks and form blocks, the ribs will be
identical.
We used a router table but you could just as easily
bolt the cutting blocks right through your table
making the routing very easy. Always messy as hell
but very easy. Eyewear is ESSENTIAL (and a hat unless
you like Al chips in your hair) and A curtain of some
sort for your cutting area will prevent getting Al
chips in every sq. mm of your workshop.
This process of course make more sense if you are
making a project with a friend and can get more use
out of your cutting blocks.
Just my 2 cents.
David
--- cookwithgas <cookwithgas(at)HOTMAIL.COM> wrote:
<cookwithgas(at)hotmail.com>
> Scott,
aluminum blanks?
> Curt
or this:
to each his own.
Good luck,
Scott Laughlin
myself.
David Barth
601 XL Plansbuilder 15% done?
Working on Wings
www.ch601.org
Looking for last minute shopping deals?
Posted: Mon Jan 21, 2008 9:00 am Post subject: Autocad drawings for CH701 form blocks? |
I plan to set up a camping tent in my garage. Then I'll do the router cuts
in the tent. Then I'll shake out the filings when I'm done.
Curt
gboothe5(at)comcast.net Guest
Posted: Mon Jan 21, 2008 9:14 am Post subject: Autocad drawings for CH701 form blocks? |
I did my center section ribs all at once with this method...worked very
well! Don't forget to wear hearing protection so that you don't know what a
p.i.a you are to your neighbors (plausible deniability).
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
ifly4fun2(at)sbcglobal.ne Guest
Posted: Mon Jan 21, 2008 9:40 am Post subject: Autocad drawings for CH701 form blocks? |
Curt,
Excellent idea, thanks for sharing I'll do the same.
Art
Curt
